Gold Member Username: Loc_outTeam RE XXX Post Number: 2711 Registered: Feb-05 | What's up guys?? As some of you guys know I fiberglass my front doors to fit a 6 1/2 and a 5.25 ![]() I also bought a second set of mmats pro 651 for my rear doors. After making the rings i realize they are not going to fit.I am about to fit two 5.25. My option is buy a 5.25 mid woofer for 70 bucks(140 a pair)? Second option is install 6 ½ on and the tweeter on the rear door. Fiberglass the front pillars for the 5.25. Which do you guys think I should do? Below is a pix of option 2. ![]() |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1619 Registered: Mar-07 | looks nice bud cant help you with the placement though sorry |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9472 Registered: Jul-06 | Nice fabrication there and nice equipment. As for the rears you don't need them..... but if you insist, using the exact same speakers is the correct way to do it. |
Silver Member Username: TreezIts not loud til it he... Post Number: 415 Registered: Aug-06 | If you do insist on rear fills i'd go for option 1 as M.S suggested. Option 2 would require active filtering on the 5.25 mid for a very narrow bandwidth (perhaps 1khz to 5khz). However, very precise tuning will be required to achieve seamless blending between these mids and the other HF drivers. |
Platinum Member Username: GlasswolfNW, MI USA Post Number: 12294 Registered: Dec-03 | gorgeous glass work. go with 5.25" in the rear doors, no tweeters, and use a bandpass filter on them, with a Q factor of about 18dB @ 500-5KHz, and wire the rears in series, on a bridged pair of amp channels (mono wiring) to avoid destroying your front stage imaging. here's a bit more on rear fill theory: http://www.glasswolf.net/papers/rearfill.html |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2182 Registered: May-07 | D@mn Glasswolf... I have A LOT of learning to do. lol Nice site btw... Been a while since i have been there. |
Silver Member Username: WickedbassNashville, Tn Post Number: 297 Registered: Jan-08 | "gorgeous glass work." ^^^x2 |
Platinum Member Username: InsearchofbassPost Number: 11175 Registered: Jun-04 | Nice work. |
Silver Member Username: ShadeMoxee, Wa U.S. Post Number: 827 Registered: Nov-06 | Those are Tahoe or yukon doors correct? What's the max mounting depth on those doors? Would 2 pair of 6.5's fit in the front doors? sorry for all the questions |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2205 Registered: May-07 | Nice work Lowlife. |
Gold Member Username: Loc_outTeam RE XXX Post Number: 2714 Registered: Feb-05 | Thanks everyone. I will take Glass advice. Those are Tahoe or yukon doors correct? Wrong Avalanche, same as a Hoe or Yukon. What's the max mounting depth on those doors? I dont really know Would 2 pair of 6.5's fit in the front doors? Yes Hope that helps |
