My RS-232 cable
Username: Hockeycraze12000
Post Number: 31
hi everybody
i was just wondering if the cable i use for transferring files on fortec lifetime ultra (works perfectly) will work on every other reciever as well?
thanks a lot
Username: King_of_sats
Post Number: 694
NO !
Some STB's are standard rs-232 and others crossovers (null)
Post Number: 32
which recievers do my cable work on?
(i dont know if mine is standard or crossover, but it does work for a FORTEC LIFETIME ULTRA)
Username: Nydas
Post Number: 13799
Khalid: The cable you have is a straight RS-232. The other type is called a Null modem cable. The PINs 2 and 3 are switched there.
More receivers use Null Modem cable. If the cable you have does not work, you will either have to buy a DB9 F/F cable or buy a DB9 M/F Null adaptor.
The null cable will work directly or the null adaptor and you original cable will become a null cable.
Post Number: 33
So are their null adapters out for the straight cable?
And what recievers do the null and straight work on?
Thanks.
Username: Runnerguy
Pluto
Post Number: 1732
What CABLE to use with various FTA makes?
Here is a list of the most popular receivers on the market and the cable needed to program them.
Ariza Ultra 400/500- Null
Astrovox 2600-Straight DB9
Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null
Co0lsat 4000 Plus-Null
Co0lsat 4000 Pro-Straight DB9
Cooltec-Null
Coship (All)-Null
Digiwave 6800/7000-Null
Digiwave Diamond-Straight DB9
Dreambox (All)-Null
Fortec lifetime-Straight DB9
Fortec Lifetime Ultra-Straight DB9
Lava 2600-Null
Max 2500-Null
****sat (All)-Straight DB9
Microroyal (All)-Null
Pansat 2300a/2500a and all clones-Straight DB9
Pansat 2700-Null
Pansat 3500-Null
Pansat 5000HC-Null(Also can program through USB)
Pantec/Multistar Max (All)-Null
Pantec/Multistar MS (All except MS1000)-Straight DB9
Pantec MX/Ultra-Straight DB9
Rex1-Null
Silver bullet/ST 1000/2000-Null
Skyview 500-Straight DB9
Spacestar DVB500-null
Stealth 2000a-Null
Ultrastar 5000-Null
Viewsat VS2000-Null
List of Popular Receivers Firmware Cable
NULL MODEM CABLE (Cross over )
* Ariza Ultra 400/500/700/750/800 & Extreme - Null modem cable
* Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II. MS1000, ,etc.)- Null cable
* Bluejay 1 & 2 -Null modem cable
* Buzz S2010F - Null modem cable
* Captive Works 1000s (CW500s,CW600s, CW600s Premium) - Null
* Co0lsat 4000 Plus-Null
* Cooltec ( Clones only ) - Null
* Coship (All)-Null
* Digiwave 6800/7000-Null
* Dreambox (All)-Null
* ExtremeView Magnam XV3300 - Null
* Koolsat/Sonicsat (clone) - Null
* Kusat Pro 2600a - Null
* Lava 2600-Null
* Max 2500-Null
* Microroyal (All)-Null
* Neusat SP6000 ( SP6000 Premium ) -Null (Also can program through USB)
* Orasat v5- Null
* Pansat 2700-Null
* Pansat 3500s/sd - Null Cables - (Also SD Memory Card)
* Pansat 5000HC-Null modem cable(Also can program through USB)
* Pantec/Multistar Max (All)=Null
* Rex1-Null
* Silver bullet/ST 1000/2000-Null
* Skyview RX600 - Null
* Spacestar DVB500-Null
* Stealth 2000 * Techsat - Null
* Ultrastar 5000-Null
* Viewsat VS200- NULL -------------------------------------------------------------------------------- -------------------------------------------------------------------- STRAIGHT THROUGH CABLE
Astrovox 2600-Straight through DB9
Co0lsat 4000 Pro/5000Pro/5000Platinum/6000Premium-Straight DB9
Cooltec ( Non Clone ) -Sraight through DB9
Fortec lifetime-Straight through DB9
Fortec Lifetime Ultra-Straight through DB9
lava 3200- straight through db9
Megasat (All)-Straight through DB9
Pansat 1500a/2300a/2500a and all clones-Straight DB9
Pantec/Multistar MS (All except MS1000)-Straight through DB9
Pantec MX/Ultra-Straight through DB9 Skyview 500-Straight through DB9 Andy
