Viewsat Files and Pansat FIles and more
Username: Halo
Toronto, Ontario Canada
Post Number: 685
All the files are posted at www.dishkeys. co.nr keep checking for more to be posted!
Username: Nydas
Post Number: 13781
Always go to "home site of your receiver" first. The sites in BOLD offer direct downloads without registration.
[link removed] - VIEWSATS
[link removed] - Ariza and Pansat Conversions and Clones
[link removed] - SONICVIEW
[link removed] - Pansats, Viewsats, Sonicview
[link removed] - CaptiveWorks.
[link removed] - Nfusion
Other reliable sites:
[link removed]
Username: Sjain80
Post Number: 144
hey guys.. are the files working or there seems to be some problem with the new file. ihave been to few different websites and everyone have different answer.. I know ftahq have been down since yesterday but I downloaded a file from dsstester and it doesn't work.. thanks for the info
Username: Hypmind
Post Number: 10
Does anyone know where I can get the newest keys?? I have a fortec star reciever I have to put in the keys manually to the receiver can any one here help me please
Username: Hypmind
Post Number: 11
Username: Nydas
Post Number: 13790
Tito:
1. First of all decide whether you have a Pansat 2700 or a Fortec star receiver.
These are two different receivers.
2. If it is Fortec Star, is it Fortec Star Ultra?
3. Keys are generally not required nowadays. You probably need a new BIN.
4. If you are not sure what you have, go into Menu/System, and post EXACTLY what you see.
Username: Joel16
Good Day
I have switched to VS PVR700 I was able to load 122208 but 010908 gets me "no video or audio" VS plat would tell me it was autorolling. I guess the 700 doesn't.
is it me? or a bad BIN? Nailin?
Username: Sjain80
Post Number: 149
joel,
VS PVR7000 new bin isn't working.. that is the only receiver that isn't working right now.. have patience and hopefully a new bin should be out soon. 010908 will not work....hope that helps
Username: Joel16
Thank you Shawn
Username: Hect
hi everybody i am looking for help to install the nfusion nuvinio SD. can anybody help me with that
Username: 3dges
Compton
Post Number: 126
no new files for Viewsat Ultra
