Puff version 203v2 doesn't work
Username: Harry_longfellow
Post Number: 31
When loaded Puff 203v2 remains black. Puff 295 and Puff 301 freeze every 2 minutes. A new bin is needed
Username: Tscon
Post Number: 111
Exactly.
Post Number: 32
Actually, The bin Puff 203v2 does work. The key is to follow Nalin's directions exactly and make sure that all the channels lists are deleted, reset the box and you only use the blind scan instead of the other scan options. Thats what I was doing wrong. Thanks Nalin
