PUFF_300 for FLU/2500 Conversion to 2700 Full kits for Latest conversion BINs and other files - also for Revert to 2500 Remove Channel list before installing
[link removed]
Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. Please note, you may need to rescan
Since turning the receiver off from the back, appears to no longer be an issue, is everyone loading them as before? Or are they continuing to shut them down at the first sign of the P?
Sorry for the stupid question, but I have a pansat 2500a and I converted it to use PUFF BINs. But I was looking for a new box that would be HD. I was wondering if anyone knew what I should pick. I don't know much about this and I wanted to know which box to pick and if they work just like the old pansat 2500a that needs a new bin every few days. Thank you!
When ECMs occur, almost all receivers are affected simultaneously. When new BINs are published, some receivers come out with a new file a few hours after others. Notable exception lately is C00LSAT 4000, 5000, 6000, where it takes 2-6 days for new files. Nfusion seems to remain up more often through ECMs than others. I suggest you use the search facility to find out about HD receivers. There have been about 10 thread in the last one month on this subject.
