Username: Pistol_pete Cavalier,
Nd
United states
Post Number: 1 Registered: Jan-09
Thursday, January 15, 2009 - 20:55 GMT i have a jl audio 12 w6v2 sub and i have it hooked up to a 800 watt california amp. im wondering if it to much power for the sub or not
Username: Wickedbass Nashville,
Tn
Post Number: 303 Registered: Jan-08
Thursday, January 15, 2009 - 21:08 GMT It should be fine as long as its given clean power.
Username: Hittin1 TEAM REVOLUTIONLake Charles...
Post Number: 2193 Registered: May-07
Thursday, January 15, 2009 - 21:09 GMT give exact amp make/model and voice coil configuration on the sub.
Nd
United states
Post Number: 4 Registered: Jan-09
Thursday, January 15, 2009 - 21:26 GMT the amp is a 800 watt california two channel amp and i have the sub hooked up parallel which is at 2 ohms but ive noticed that it streches alot
Post Number: 2200 Registered: May-07
Thursday, January 15, 2009 - 22:19 GMT hmmmmm. by "stretches" i assume uyou mean excursion. i still need to know exact model of amp.
Username: Insearchofbass Post Number: 11174 Registered: Jun-04
Thursday, January 15, 2009 - 22:22 GMT I believe California is a profile amp.
Post Number: 2201 Registered: May-07
Thursday, January 15, 2009 - 22:41 GMT It is, but i couldn't find a 800 watt 2- channel.
Username: Insearchofbass Post Number: 11177 Registered: Jun-04
Thursday, January 15, 2009 - 22:53 GMT Its probably this one.... Profile Clarus CL800 CL800 Profile CL800 Clarus 800W 2 Channel Chrome Amplifier Clarus 800W 2 Channel Chrome Amplifier MOSFET Power Supply Bridgeable/Tri-way Operation High Current Cable Ports Speaker Level Inputs Three-Way Smart Protection Variable HP/LP Crossover(40~500Hz) 0-18dB Variable Bass Boost@45Hz Power Light Strip Preamp Outputs 2 Ohms Stable Stereo 400W x 2 Peak Output Power 200W x 2 RMS Output Power (4 Ohms) 300W x 2 RMS Output Power (2 Ohms) 600W x 1 Bridged Output Power (4 Ohms) Size (H x D x W): 2 5/8" x 10" x 15 7/8"
Post Number: 2202 Registered: May-07
Thursday, January 15, 2009 - 23:33 GMT if that amp does rated power than it should not be too much power for the sub. do not turn bass boost on.
