Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1576 Registered: Mar-07 | im FINALLY about to install my comps (cdt es 62-i's) and was wondering if i could run a small amp to the tweets or if im better just to run them off the HU? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9428 Registered: Jul-06 | Oh man. That question itself shows you don't know how to install an active crossover system. All speakers need to be powered by an amplifier. A 4 ch is the simpliest way. Then you need an active crossover installed before the amp. And then you have to know how to tune it or say goodbye to those tweeters. |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1579 Registered: Mar-07 | ya im having it installed i DONT know how to do it. i have an old clarion amp that is small i wanted to use it and then i have a 2 chanel for the comps |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1580 Registered: Mar-07 | here are the specs The specs are as follows. Maximum Power Output: 100W (50W/channel) Continuous Average Power Output: 30W/channel into 4 ohms Frequency Response: 10-50 Hz Signal to Noise Ration: 105 dB or better Input Sesitivity: 200 mV - 4 V Current Consumption: 8 amps Speaker Load Capacity: 2 ohms Dimensions: 226mm W x 53mm H x 142mm L |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9430 Registered: Jul-06 | That will work, just enough power for tweeters. just make sure whoevers installing it knows wtf they're doing. And do you have a crossover yet? You need an active one to send low pass to mids amp and high pass to tweeter amp. And the set HPF on the mids amp to block out bass, or on the xover if it has that. A 3-way xover is ideal for this, it will connect to sub, mid, and tweeter amps and handle all crossover functions. And you have to find out the right xover frequencey to set for your speficic components..... |
Gold Member Username: camBC Canada Post Number: 2568 Registered: Nov-06 | When you say "comps", what do you mean? The component system is made up of the mid woofers and the tweeters in this case. "Frequency Response: 10-50 Hz" Waaap waaaap waaaaap waahwahwahwah |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9431 Registered: Jul-06 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&product_id=1259 There is a top of the line model. But there are some other decent brands that make them for less. Just don't get a crap brand. |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1581 Registered: Mar-07 | they came with xovers i assume they are for the tweets and mids go to amp directly? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9432 Registered: Jul-06 | " The component system is made up of the mid woofers and the tweeters in this case. " No really ![]() You have to find the correct frequencey to crossover sound between the mid and tweeter. Frequency Response: 10-50 Hz Has to be a typo... what model amp |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1582 Registered: Mar-07 | does it matter where i mount the xovers? like do they need to be as close as possible to the speaker im mounting everthing and runing the power just having him wire it to the correct ohms and tune it in thanks for the help |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9433 Registered: Jul-06 | Lets try this again. Whats included are PASSIVE crossovers. If you use those you can only connect everything to ONE AMP. Running the mid and tweeter on seperate amps requires an ACTIVE crossover which I just showed you. The passive ones are not used in that case. |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1583 Registered: Mar-07 | clarion apa2061 my neighbor works on cars and got it from someone i think it came out of an old bmw if im not mistaken |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1584 Registered: Mar-07 | oh i see what your saying |
Gold Member Username: camBC Canada Post Number: 2570 Registered: Nov-06 | LOL whatever, MS. It sounded like he figured the mid-woofers alone were the components. Some have 6 drivers so I had to distinguish this situation. Well yeah it definitely does sound like that's a typo. The only other specs I found said the same 10-50 Hz though. Strange. |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1585 Registered: Mar-07 | must be a small sub amp |
Platinum Member Username: InsearchofbassPost Number: 11126 Registered: Jun-04 | "must be a small sub amp" Nahh. My rainbow amp has a 10hz-50k frequency range. Thats what your 10-50 means. Thats a good thing if those stats are correct for your amp. |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1586 Registered: Mar-07 | good to hear |
