New member Username: Alex333Post Number: 1 Registered: Dec-08 | Any news about N2 GC keys???? Please do not discous. about GC channels N3, Ir2. Via2/3, PV, DC-II... e.t.c. Only GC N2 keys information pleas!!! |
Gold Member Username: The_codersPost Number: 1640 Registered: Jan-08 | ![]() |
Bronze Member Username: Boss_hogPost Number: 24 Registered: Oct-08 | Alex-------If all you need is Globecast keys go here..[link removed] Globecast C101 - Last Update: 12/25/08 11:10 pm 00: 06 74 F5 FA F8 60 C1 08 59 84 6A 05 93 37 2E 64 01: 66 90 26 34 30 28 23 D7 C0 97 BD BF 86 59 D7 F5 |
Gold Member Username: PlymouthCanada Post Number: 6736 Registered: Jan-08 | Alex All paid channels are on N3 now, the keys not work for now. ![]() |
New member Username: Alex333Montreal Post Number: 2 Registered: Dec-08 | Plymouth Gold Member Username: Plymouth "Alex All paid channels are on N3 now, the keys not work for now." It's not exactly, same channels on N3, same on Ir2, bat same channels as RTR SPORT and RTR PLANETA still on N2 (CA1801). If You have Emunation console you will see what system CA use for each channel. _________________________________________ 30°, 61.5°, 82°, 91°, 97° 110°, 118.8°, 119° SS1,ProgDVB, Emunation |
Gold Member Username: PlymouthCanada Post Number: 6750 Registered: Jan-08 | Alex Are you able to get RTR Sport,Planeta? --------------------------------------- 15W,22W,30W,43W,61.5W,72W,82W,83W,85W,87W,89W,91W,93W,95W,97W,99W,101W,103W,105W ,110W,111.1W,119W121W,123W,129W Invacom QPH-031 33" Motorized dish. ![]() |
New member Username: Alex333Montreal Post Number: 3 Registered: Dec-08 | Plymouth Gold Member Username: Plymouth "Alex Are you able to get RTR Sport,Planeta?" No, about 2 weeks. Emunation shows message: "...Ch:757 - RTR Planeta Provider: Nagra2 (0xC101) CA:0x1801 ECM:0x0757(1879) Unknown ECM..." If keys not changed so Gc N2 started use new ECM. |
Gold Member Username: PlymouthCanada Post Number: 6755 Registered: Jan-08 | Alex Globecast perform a New Smart Card now, so i don't think that we are able to get any paid channels. ![]() |
New member Username: Alex333Montreal Post Number: 4 Registered: Dec-08 | May be RSA key has changed? I use RSA key: N C101 M1 336991F2DD42C0EC25597B75DBDDF751CF069CF32DDDBC308453F4B60506A59D652FAC9BADFE168C A75EDB18AFCAC0E9827D7A4447AAE1FC00EABD0213CAAE87 N C101 X1 03; Plymouth, can You confirm what it's correct? Thank's |
Gold Member Username: PlymouthCanada Post Number: 6756 Registered: Jan-08 | Alex Where you take those keys, which receiver? ![]() |
New member Username: Alex333Montreal Post Number: 5 Registered: Dec-08 | In the file Softcame.key for DVB applications. I use ProgDVB and DVB card Sky Star-1 rev.1.5 |
Gold Member Username: PlymouthCanada Post Number: 6758 Registered: Jan-08 | Alex DVB Card for PC, i have 2 cards but never try it. ![]() |
Bronze Member Username: KakapapaPost Number: 42 Registered: Sep-06 | Any new key or bin for GC?? |
Gold Member Username: PlymouthCanada Post Number: 6811 Registered: Jan-08 | Kaka Forget it GC is on N3 now. ![]() |
New member Username: Eagle159Post Number: 3 Registered: Jan-09 | Hi, Until two weeks ago I could get all channels in both posionts (vertikal/horizontal) on GC sattelite. But, after I can't get any channel on Horizontal position, and also many others on vertical position I can;t get them, because signal is weak. Just to let you know that day before it was high wind. Anyone knows how to fix this problem? Thank you in advance! |
Gold Member Username: PlymouthCanada Post Number: 6819 Registered: Jan-08 | Frank i give you answer on this thread: https://www.ecoustics.com/electronics/forum/home-video/540922.html ![]() |
New member Username: Eagle159Post Number: 5 Registered: Jan-09 | Yes I got it there, thanks mate ![]() |
