PROBLEM STARTED IN OCT STILL UNDER EXTENDED WARRANTY 2 YR OLD TV STARTED GETTING WHITE SPOT THAT MULTIPLIED EVERY DAY WHILE IT TOOK CIRCUIT CITY 1 MONTH TO GET SOMEONE OUT TO LOOK AT THE TV THEY DETERMINED A BAD ENGINE AND ORDERED THE PART AND REPLACED THE ENGINE ON NOV 24 THAT SEEMED TO FIX THE PROBLEM BUT WAS OUT OF TOWN AND REALLY DID NOT HAVE TV ON MUCH UNTIL CHRISTMAS WEEK MY SON TURN ON TV AND SAID THE PICTURE WAS BAD AND THE TV WOULD CUT OFF SO I POWER IT UP AND LOOK IN THE BACK OF TV AND COULD SEE A LOOSE CONNECTION HEATING UP ON THE LAMP HOUSING WHICH CAME WITH THE NEW ENGINE SO I CALL CIRCUIT CITY DAY AFTER CHRISTMAS AND THEY SAY MY EXTENDED WARRANTY IS OUT BUT I SAY IS THERE NO WARRANTY ON THE PART WHICH YOU JUST RELACED AND THEY SAID THERE WAS A 30 DAY SERV WORK WARRANTY BUT I CALLED IN ON 26 OF DEC AND I AM 2 DAYS OVER SO CALL THE SERV TECH AND TOOK IT TO HIM AND SHOWED HIM THE PROB HE TOOK THE LAMP HOUSING OUT AND TIGHTEN A SCREW THAT WAS NOT TIGHTENED AT THE FACTORY BUT I GUESS THE LOOSE CONNECTION MUST HAVE DAMAGE SOMETHING ELSE BECAUSE I AM GETTING A KIND OF HAZE OR PHOTO NEGATIVE EFFECT IN SOME AREAS IN ALL INPUTS OF PIC PIC QUALITY IS VERY POOR THANKS FOR ANY HELP TIM
