New member Username: AjranPost Number: 1 Registered: Jan-09 | Hi, can anyone help me, I changed battery and my radio now requires security code. I have Renault Clio 2001. I like this radio and I wouldn't like to change it. Model No. 22DC229/62T Prod No. FD0101390022887 RN229F10022887 TOQ584 thnx ajranko@gmail.com |
Silver Member Username: RegroosterPost Number: 337 Registered: Aug-08 | Eki Ajran New member Username: Ajran Post Number: 1 Registered: Jan-09 Posted on Wednesday, January 07, 2009 - 01:31 pm: -------------------------------------------------------------------------------- Hi, can anyone help me, I changed battery and my radio now requires security code. I have Renault Clio 2001. I like this radio and I wouldn't like to change it. Model No. 22DC229/62T Prod No. FD0101390022887 RN229F10022887 TOQ584 You code should be 9434 |
New member Username: AjranPost Number: 2 Registered: Jan-09 | I have attached radio in my car and apropriate cables. Also I input code 9434, end don't work .Is it possible that I made some mistake, or could radio be blocked somehow? Maybe, it is necessary to appropriate procedure or some another code? Thanx for patience. |
Silver Member Username: RegroosterPost Number: 338 Registered: Aug-08 | If you have already entered any wrong codes then it might be semi-locked. Leave it SWITCHED ON ...UNDISTURBED for as long as it takes to reset itself. |
