Help Creating a Home Theatre System for less than $2000
Username: Ohbrian
My budget right now is $2000. What should i get? From the research i have done, i need to get a front, rear, sub, center, and a receiver. I would like to get things individually instead of getting them in a package. I read HTIB arent' that good from reviews. Could you please help me to get the best for $2000. THANKS!!!
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 596
Happy New Year Brian,
Your best approach is to go out shopping (not buying yet) if possible. Start at a place like Best Buy / Circuit City then work your way towards a specialty store. The only person who can determine what sounds best is yourself and with a $2000.00 budget you will have a lot of choices.
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 566
Brian $2000 is a nice start and you can get a very good set up for that. I like Denon and Paradigm. That being said I also understand that the Onkyo TX-SR606 is a hot product right now in your price range, The Paradigm Atoms where voted 2008 Joint Budget Products of the Year
http://onkyousa.com/model.cfm?m=TX-SR606&class=Receiver&p=i
http://paradigm.com/en/paradigm/fronts-monitor-series-1-2-4.paradigm
Add a center, surrounds and a sub and your set.
