Bronze Member Username: KissdaredevilPost Number: 62 Registered: Aug-06 | I have 2 infinity 1252w's, they have a dual 4 ohm voice coil. I was wondering if I should get a 2 channel amp because then I could bridge each channel down to 2 ohms. Or should I get a mono, but if I get a mono I can only bridge it down to 4 ohm. |
Gold Member Username: BonhamdTraverse City, MI Post Number: 1689 Registered: Nov-07 | 2 dual 4s can wire to either 4 ohms or 1 ohm those subs are rated at 300 RMS. i would recommend getting a mono block that puts 600-800 RMS into 1 ohm. see the wiring diagrams below http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 |
New member Username: StaffsgtspazPost Number: 2 Registered: Feb-09 | Hey, I just started a system of my own and I got (used ) 2 10' old kickers and an Orion 225 HCCA digital. BOTH KICK BUM!! Kickers will boom like no tomorrow. If you add the Orion to its own battery (I got mine to a massive marine battery) it has its own power, so its not starved per say. It gets around 400-600 if it has its own supply and is wired right. Thats just on one ohm. It works good so if you need power try to pick one up. Orion hcca are well known tho so I got very lucky to get it :D |
