problem is> i only get 209 stations on 119 and 106 on 110 and 22 on 61.5. i susspect antena setup. if i hook the real dn box up i get stations that are missing on the viewsat.
i have a DP dual and a separate single for 61.5. from the set i have a little almost square switch loocks like an old diseqc. (been painted many times)..I'm thinking it could be a legasy switch?????
in my setup i set the 110&119 as legacy sw21 dish 1 , lnb type legacy twin lnb 1&2. the 61.5 is sw21 dish 2 and standard lnb.
help???
some times at night some of tghe stations will come in (history and 138 come and go)
so when you tell it that 110 and 119 are LNB Type on OCS-DP. it knows that 119 is 1 and 110 is port 2? there is no need to set a port as though it had dieqc switch..I will try whet you said and reply after work today.. thanks for your help LOU
