Username: That_guy_u_dont_know Kaplan,
Louisiana
United States
Post Number: 58 Registered: Dec-08
Friday, January 02, 2009 - 21:25 GMT i hooked my amp up put hooked up the sub nothing comes out the sub at all not even a slight movement at any volume and yes everything is hooked up right wat could this be?
Username: Talon01 Team Revolution ,
Pa
Usa
Post Number: 1946 Registered: Jun-07
Friday, January 02, 2009 - 21:31 GMT power light on?
Louisiana
United States
Post Number: 59 Registered: Dec-08
Friday, January 02, 2009 - 21:33 GMT yeap the power light is green and not blinking nothing
1000 posts!!
Post Number: 19547 Registered: Jun-06
Friday, January 02, 2009 - 21:37 GMT Muted?
Pa
Usa
Post Number: 1947 Registered: Jun-07
Friday, January 02, 2009 - 21:38 GMT rca's connected? get a 9v batt and touch the speaker wires from the sub to the connections on top and see if it pops. just tap it dont hold it!!!
Louisiana
United States
Post Number: 60 Registered: Dec-08
Friday, January 02, 2009 - 21:40 GMT rcas or connected and that sounds like it will mess up something rather not risk that and paul im not that stupid
Pa
Usa
Post Number: 1948 Registered: Jun-07
Friday, January 02, 2009 - 21:43 GMT do you have any way to test the sub? new or used? it wont hurt it btw i do it all the time. correct rca connect from hu?
Louisiana
United States
Post Number: 63 Registered: Dec-08
Friday, January 02, 2009 - 21:52 GMT i had my L7 15 hooked up to it and it worked fine took it out cause i sold it and i had a old JL 10 layin around so i decided to hook it up and well nothing happens (i took the amp out with the L7 then put it back in when i wanted to put the 10 in)used sub i have it hooked up in my room and its workin so i dont think its the sub yea the rcas or connected right i havent changed anything since the last time the amp was in
1000 posts!!
Post Number: 19548 Registered: Jun-06
Friday, January 02, 2009 - 22:08 GMT "and paul im not that stupid" Well sometimes I am so it never hurts to ask. Take a close look at the tinsel leads.
Username: Somedonniedude Illinois
Braaap MX
Post Number: 2241 Registered: May-07
Friday, January 02, 2009 - 22:11 GMT Test your amps output with a multi-meter and your box terminals to see if everything is hooked up.
Louisiana
United States
Post Number: 64 Registered: Dec-08
Friday, January 02, 2009 - 22:13 GMT no terminal straight to sub..... tinsel leads? that would be and yes i know stupid question
Username: Tylersliva St.Ignace,
Mi
U.S.
Post Number: 120 Registered: Oct-08
Saturday, January 03, 2009 - 00:08 GMT u know what i would do i would find someone that will let you try and hook their sub to it and see if it works... if it dont work somthin is wrong with amp... check all fuses and connections
1000 posts!!
Post Number: 19550 Registered: Jun-06
Saturday, January 03, 2009 - 00:27 GMT Tinsel leads. You know, the thin silvery wires that connect the coil to the terminals? Check to see if one of them jarred loose. It happens.
Louisiana
United States
Post Number: 65 Registered: Dec-08
Saturday, January 03, 2009 - 06:57 GMT i got it guys i changed the rcas to a diffrent one and it seems to work now lol
