Amp and Preamp????
Username: Cla6665
Soon I'll be receiving my marantz 4140 integrated quadraphonic power amp. I was wondering if I need to get a preamp to. I am planning to listen mainly to cd's and some vinyl.The amp already has bass middle and treble adjustments. I would like to put together a nice "old style" set up. The 4140 is rated at 70 watts in two channel and 25 in4. If I do get a preamp how many watts does it need to have?
Thank you very much
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1918
None.
Your power amp has all the watts.
Username: Jazzman71
Phoenix, AZ USA
Post Number: 482
Claudio, the fact it is an "integrated" amp means the preamp and power amplifier are combined in the same unit. A preamp will not add power since the output to the power amp section will be similar to the unit's internal preamp. In fact, in order to even use a preamp, the unit must have "main amp in" connections that allow the internal preamp to be bypassed. I was not a 4-channel amplifier owner when they were being made, and I don't know what the back of this looks like, but you don't need a preamp. Spend your money on some of those rare quadrophonic LPs.
