Acoustimass 25 Series II speaker system.
Username: Rexfreddy
Whittier, Ca. USA
After approx. 10 min. the spkrs. cut out.
Sometimes w/a loud pop or just go dead. The problem is in the base unit. Possibly "CRYSTAL", but need assistance. Thank You;
-Rex-
Username: Artk
Albany, Oregon USA
Post Number: 8732
Take it to your nearest Bose service center or scrap it and start from scratch.
Username: Barry_nj
GSP Exit 165, New Jersey
Post Number: 16
I'd recommend the latter of Art's recommendations
Username: Edison
Glendale, CA US
Post Number: 862
Yeh, you can get much better sound than the Bose - you are in for a treat - your ears will thank you.
Username: Nuck
Post Number: 11466
Not a lot of Bose admirers here Rex.
I would shop
