Bronze Member Username: MatiPost Number: 34 Registered: Apr-08 | How can i get Amazonas Salelite for CW600S And CW600P for Pansat2700A Highly appreciate your cooperation. Regards, Eugene |
Gold Member Username: RunnerguyPluto Post Number: 1722 Registered: Sep-06 | 61.0 West...... http://www.lyngsat dot com/amazonas.html |
Gold Member Username: PlymouthCanada Post Number: 6667 Registered: Jan-08 | Eugene Where are you located? You can't get any channels in Canada and USA from this satellites. ![]() |
Silver Member Username: Fakeman1Germantown, Maryland USA Post Number: 201 Registered: Jul-08 | yugene Albert, You can get TV channels from Amazonas Satellite with a C-band Installation. Check zulu post above and you will see what is available on C-band. ![]() |
Bronze Member Username: MatiPost Number: 35 Registered: Apr-08 | How can i get Amazone Satelite Antenna setup for CW-600p CW-600s for Pansat 2700A Software. I Caribe Netherlands Antilles Regards, |
Gold Member Username: PlymouthCanada Post Number: 6670 Registered: Jan-08 | Eugene Where is located Caribe Netherlands Antilles? |
Bronze Member Username: MatiPost Number: 36 Registered: Apr-08 | Where is located Caribean sea Netherlands Antilles Willemstad Curacao Netherland Antilles |
Gold Member Username: PlymouthCanada Post Number: 6672 Registered: Jan-08 | OK i found Try to enter the keys Manually, but you can ask on Hispano forum for help: https://www.ecoustics.com/electronics/forum/home-video/399884.html Here is the keys: TelefA³nica TV (7311) [Last update: Tues. Dec. 16, 2:23 PM CDT] 86: 1E 8E DF D4 B9 9A 2E D1 C8 D3 42 75 98 82 5E 0A New 96: BF D4 15 27 45 9D 9C 2F 33 85 D0 A8 0E 7A 56 B3 ![]() |
Bronze Member Username: MatiPost Number: 37 Registered: Apr-08 | Thank very Much Where can i find the key? WWW.? Regards, |
Gold Member Username: PlymouthCanada Post Number: 6682 Registered: Jan-08 | Eugene You are Welcome dss-keys.com tvkeyz.com ![]() |
Bronze Member Username: MatiPost Number: 38 Registered: Apr-08 | Hi plymoth When i enter the number in my Pansat 2700A it still give me wait for picture My location is in the Carribean sea just in the north coast of Venezuela My country Curacao, Willemstad Netherlands Antilles , my CW-600s Antenna setup for Amazonas is not list regards, Eugene |
Silver Member Username: PicanhaEast LA Post Number: 206 Registered: Jun-08 | yugene .... Volver a la Pareja Espanol parte de este foro y haga sus preguntas en EspaA±ol. La gente de allA estAn mA's familiarizados con el problema. |
Bronze Member Username: CalifirniaPost Number: 76 Registered: Apr-06 | tvkeyz dot com |
Gold Member Username: DimwittPost Number: 1015 Registered: Aug-06 | The cw600s/p don't support amazonas. Telefonica keys Created Time: 24/Dec/2008 ( 7311 - 01 ) - 84 F3 3B F3 C1 66 03 EE 8A 86 B7 14 F2 9E E9 01 |
