Is this file working? Fwank7_Jvvh-Team-PUFF_V203_F_EMU
Username: Jdelat
Post Number: 12
Does anyone know if this file is working?
Username: Juancho
CANADA Xx
Post Number: 365
Yes. it does, I am using it.
Username: Jdelat
Post Number: 13
Thanks Juan are you still missing some of the channels. I am still gettin only about 65% of them.
Username: Letmeon
Post Number: 256
Does this bin drop the channel list ?sometimes, and rescanning is the only
solution
Username: Justforhahas
Post Number: 1598
Fwank7_Jvvh-Team-PUFF_V203(V-2)
http://www.ftabins.net/showthread.php?p=369126#post369126
Thanks to Jvvh5897 for showing us the way once again.
I have tested the following personally on 2 recievers for over 10 hours.
-Don't lose channel list at all not even after loading bin to reciever. Tested that on 3 recievers.
-Powerd OFF reciever from back switch for 3 hours then turned reciever ON channel list remains.
-Powerd OFF/ON reciever from back switch over 10 times channel list remains.
-Turned OFF with remote for 3 hours and came back ON no problems.
-Used Channel Master to read reciever No problems.
-Used Channel Master with old Channel List and wrote to reciever No problems.
-Still tried scanning All Sats and All good there as well.
-Still get the odd black screen but that happens on Original 2700 also.
Don't think I missed anything else.
Turn A/R OFF (except Key Code) if your reciever has rebooting issues or "SOBC" Nag issues.
"Original 2700 Bin Modified & Compressed by Fwank7"
Using "Jvvh" name in bin as a sign of respect to the 2500 to 2700 conversion creator."
Username: Lubfr01
Post Number: 34
can you use this on FLU converted to Pansat 2700 box?
Post Number: 1599
sure can...yes.
Username: Machedonul
Post Number: 425
why are the past 2 bins messing up the channel lists and loading them has become a totally different process? just curious...
Username: Cecilmac2
Post Number: 30
when i load bin for fortec star it stoped at number 5 and does nothing can someone help.
thanks cecilmac2
Username: Cecilmac2
Post Number: 31
thanks cecilmac2
Username: Mkvl1490
Post Number: 167
Hopefully this is better than that god awful tronics 202 bin
Username: Mkvl1490
Post Number: 168
THANK YOU JVVH
Username: Psychmonster
Rhodium Member aint nuthin...
Post Number: 1000
Ha Ha's stepping up to fill the void....just straight talk with no bs or banners or links...should be interesting when she gets back from vacation ...with that awful parrot on her shoulder (plymouth..polly wanna cracker)
Username: Plymouth
Post Number: 6527
Congrat psycomonster you are Gold now
Username: Master_lee
Post Number: 157
psychmonster Congratulations,
You don't say much, but when you do
there is no BS.
Username: Mkvl1490
Post Number: 169
Might have spoke a little too soon
119 is not working
Username: Yashmatharu
Brampton, Ont Canada
Post Number: 243
my is not working. I have PUFF but it show 75.
Did I do something wrong?
Username: Cartier1
Post Number: 2268
NO IN THE END WHEN IT BOOT UP IT WILL SHOW -75- . AFTER SCANNING DO A HARD BOOT YOU WILL GET UR CHANNELS
Username: Indopak
Post Number: 139
i have uploaded the file to my fortec lifetime ultra, and it says -75- too. but its not working? why is that?
Username: Cartier1
Post Number: 2270
FIRST YOU GOT TO COVERT TO PUFF. AFTER CONVERTING YOU USE THIS LATEST BIN . YOU SCAN AND U TURN OFF FROM THE BACK . IF U THINK U ALREADY CONVERT DO IT AGAIN. MAKE SURE OF YOUR SET UP . THERE NO WAU THAT WORK FOR THE OTHER AND NOT FOR YOU . VERY IMPORTANT HARD BOOT AFTER SCANNING , GOOD LUCK
Post Number: 244
In my case it is showing scrambled channels before scanning. Do I need to scan again. What do you mean by Hard Boot?
Thanks
Username: Jaye50
Post Number: 147
i'm using fwank7's v203 (v-2)
so far it's the best bin that's been out in quite a while....
Username: Lubfr01
Post Number: 37
Hi Jaye:
Could you please list all the steps one by one you took while applying this bin....
Also someone please let us know if the steps are the same for (FLU converted to) Pansat 2700 and Original Pansat or everything is the same?
Thanks,
Frank
Username: Faras
Post Number: 12
WHAT'S A HARD BOOT ?
Username: Faras
Post Number: 13
HERE'S THE ANSWER THANKS NALIN
The Fwank7 PUFF_203V2 works.
After installing the BIN:
1. Note down your user and antenna settings.
2. Delete all chanels and doa system reset.
3. Power down.
4. Power up and do user settings.
5. Do Antenna setup for one Sat, and do a Blind scan.
6. At the end of scan you should see the picture.
7. Do other antenna set ups and scan.
8. Do your channel editing and parental controls and favourites.
9. Save this under channel master.
10. Watch TV.
Post Number: 427
what ever happened to bins working off the bat, without having to erase all your channels/blind scanning? do you guys think from now all the future bins will work the complicated way?
