New member Username: Monkey54
Post Number: 1 Registered: Dec-08
Posted on i have 2 12" jl audio w3 2 ohms. what size amp should i get? there rms is 300 and peak is 500 for each |
New member Username: Joshualittle
Columbus,
Ohio
United states
Post Number: 6 Registered: Dec-08
Posted on I would recommend an arc audio ks 500.1 or if you wanted to go bigger an arc audio ks 1000.1. |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 9157 Registered: Jul-06
Posted on JL 500/1 if money isn't a problem |
Bronze Member Username: Tylersliva
St.Ignace,
Mi
U.S.
Post Number: 29 Registered: Oct-08
Posted on get lanzar mxa252 its 300wrms and its 2 channel |
Philadelphia,
PA
Post Number: 9296 Registered: Jul-06
Posted on ^^^ fail on so many levels Lanzar is crap class D is better than 2ch for subs 300w is not enough |
