Username: Lomna Post Number: 424 Registered: Dec-07
Monday, December 22, 2008 - 00:15 GMT Is that file going to do any good for us. I fear to loose what ever I have right now if I upload this. what your say on this? Thank you!
Username: Plymouth Canada
Post Number: 6580 Registered: Jan-08
Monday, December 22, 2008 - 00:31 GMT Devin It do same thing as do factory default and load factory bin nothing more.
Username: Lomna Post Number: 425 Registered: Dec-07
Monday, December 22, 2008 - 00:52 GMT Plymouth, did you load sysclean file or no ? Plymouth, I haven't done any think to my rec since 275 came. I do see rec locks once in a while. May be once in a day. which really doesn't bother me much. Do you think I should upload sysclean file and it will help rec to run smoothly in future ?
Post Number: 6582 Registered: Jan-08
Monday, December 22, 2008 - 01:27 GMT Devin if you delete all keys for Bev Dn and Globecast and do a factory default them load the factory bin, i think than your receiver will work great. You can try it, if it not work try SV4000sysclean for see if it is different. SV4000sysclean can be good for erase bad data as for Keys which is not deleted with a factory default and factory bin.
Username: Lomna Post Number: 426 Registered: Dec-07
Monday, December 22, 2008 - 01:45 GMT Plymouth, Thanks.
Post Number: 6583 Registered: Jan-08
Monday, December 22, 2008 - 01:50 GMT Devin You are Welcome my friend
