Audioque
Username: Harrymacpot
Post Number: 11
by the way sorry for the ? in the last thread.
anyways, has anyone ever come across the audioque 3500d. if so how was your experience w/ the amp. did it perform as stated on their website or was it another piece of s$$$ a## amp like most others w/ out spending THOUSANDS of dollars.
Username: Hittin1
Lake Charles, La. United States
Post Number: 1975
I have never used the 3500 from AQ, bugt I have experience with the 1200D and 2200D. Both were solid amps. I would not hesitate to run a AQ3500 if it was needed. Have you ever had experience with any AQ products? If not, then I will vouche for Aq. They are a worth their price and then some.
Username: Talon01
Team Revolution , Pa Usa
Post Number: 1898
i dont know from personal exp. the 3500 is the same board as the dd m3. if it is then it should do well
Username: Nd4spd18
Philadelphia, PA
Post Number: 9239
All AQ amps are good quality, and good values for the price.
