Can't load bin to CW 600S
Username: Kellergirl
Orlando, FL
Post Number: 109
I am trying to load the new freeze fix to my CW 600S, and it will not load. I press start, and nothing. I have tried the bins from 4 different sites, and none will load. Is any one else having this problem? Thanks.
Username: Plymouth
Post Number: 6535
Kellergirl
Switch off on back panel, press font button and hold then power on on back panel, now you will see "boot" relaese front button then try to download the file.
Orlando, FL
Post Number: 110
That's not working. I don't understand..I just loaded a bin last week, and it worked fine. Now it is not loading anything. :-(
Orlando, FL
Post Number: 111
I tried a new cord, and that's not working either. Could it be my box?
Username: Plymouth
Post Number: 6537
Kellergirl
I don't think your box is broke.
Do you have a message?
Which loader you use?
Orlando, FL
Post Number: 112
I use the CW loader, v1.05. I don't get an error message, it just doesn't start loading.
Username: Plymouth
Post Number: 6538
Do you use a USB to serial cable?
Username: Mrgreg
Ont. Canada
Post Number: 272
Is your patch enabled.F1 000.If it is try loader v1.07.
Orlando, FL
Post Number: 113
Yes, I am using the same cable I always use, and I have never had a problem before.
Username: Plymouth
Post Number: 6545
Kellergirl
Is it a CW 600S or 600S Premium?
Username: Plymouth
Post Number: 6546
Try this loader 1.07 as Greg says
http://www.box.net/shared/m48yj30b7g
Username: Doreenakadj
Ontario Canada
Post Number: 2292
set up the serial cable. Assuming your back switch is off at this point turn if to ON. Let the receiver do its thing till the channel number is displayed. Now with your remote turn the receiver OFF After the time is displayed either --:-- or what ever time it is (eg: 10:45) now you are in standby mode. Use what ever loader you have. Check what com ports are open, 1 is most common. If your using a USB serial cable try com 3 or what ever one is open. Here is a utility to check for open com ports on your computer.
application/octet-streamUpload
check com ports.rar (4.7 k)
Username: Mohamad_obama
Terhan, Iran Iran
Post Number: 270
Great post Doreen.
Username: Plymouth
Post Number: 6549
Doreen i had same problem with loader v1.05, since i use v1.07 i have no problem at all.
Ontario Canada
Post Number: 2296
Upload Moh...
Plymouth there's a new loader out called CW600 Premium new interface.exe
http://mike.dynip.com/phcdl/file.php?id=18
May work on CW600s but not sure...use at own risk... works for me on CW600P
http://mike.dynip.com/phcdl/category.php?id=20
newest bin files (fix freezing)Dec 19, 2008
CW600S_Premium_V2.15.zip
CW600S_Regular_V2.11.zip
Username: Plymouth
Post Number: 6551
Doreen i use this one on picture, as you i don't knowi if it work for 600S.
Orlando, FL
Post Number: 114
Nope, the loader didn't work. I am guessing it is my cable, will try another one tomorrow.
Ontario Canada
Post Number: 2309
kellergirl cables do break ...pins missing or bent... check that out first b4 buying a new one
Username: Plymouth
Post Number: 6568
Good luck
Orlando, FL
Post Number: 115
