Quick question
Username: Hittin1
Team RD Audio Lake Cha..., La. United States
Post Number: 2036
If you were planning on eventually running 10K+ worth of power, Would you give up your A/C for a second alt.?
I really like the A/C(i live in the South).
But so far as I know that is the only spot (that brackets are made)to mount a second Alt.
opinions?
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2511
i wouldnt i love the ac and i live in massachusetts. i cant imagine living in the south with no ac
i would go a little less power and get lots of batterys and save the a/c
Username: Hittin1
Post Number: 2037
well that amps are pretty much set. Already have 1 RD5750.1. Will eventually strap two of 'em.
Username: Semperfi
Post Number: 36
make a seperate compartment all together and just get like 3 of 4 300amp alts... i remember seeing some picture where a guy had like 7 of them strapped together outside of his truck..
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2038
That would require ALOT of research on my part. I will check into it but that wouldn't really help as a daily driver.
Only way I can really justify givin' up A/C is that my windows stay down to let the 18's breathe.. Trust me when I say it helps... keep in mind that the 3-18's will be in a B-Pillar wall.
Username: Semperfi
Post Number: 37
well, i guess what you could do is build two ports, one above your head and the other above the passenger and use the ports as an air conditioner...
Username: Hittin1
Post Number: 2041
-_-
lol
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2579
I never run my AC anyway lol, so I'd do it. The fan works just fine for me.
Username: That_guy_u_dont_know
Kaplan, Louisiana United States
Post Number: 24
wats a RD? where u get that kind of amp?
Username: Hittin1
Post Number: 2042
I got mine from the owner of RD audio, Steve Miller. I'm waiting to hear from him about your situation.. The holidays are keeping people busy.
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 444
"wats a RD? where u get that kind of amp?"
www.rdaudio.net
or Kevin Holden
Username: Hittin1
Post Number: 2043
Revolution Design Audio.
http://www.rdaudio.net/rd5750/rd5750.htm
Username: Nd4spd18
Philadelphia, PA
Post Number: 9293
Living in the northeast i only run my AC a handful of times per year during heatwaves..... but I would probably die without it down south
Username: Tylersliva
St.Ignace, Mi U.S.
Post Number: 32
ya i would mount your ac some where else if possible
Username: Hittin1
Post Number: 2047
tyler- if i could do that i would just mount alt there instead.
A pic is worth 1000 posts!!
Post Number: 19435
For most people bumpin' they have their windows down anyway so what's the bother with ac lol?
Username: •cam•
BC Canada
Post Number: 2557
Make a fake blower so you have the space, cut a hole in your hood, fabricate a half-assed bracket, and jam in 4 stock alts from the junk yard. And while you're at the high school using the welder and plasma cutter, mack on some young chicks.
Username: Hittin1
Post Number: 2050
Username: Big_edge_head
Milwaukee, WI
Post Number: 3186
Who cares about AC. I just like rolling down the windows :-)
Username: Joebruce
TC Sounds/DLS
Post Number: 2520
Why would you want that much power for a daily driver anyways? That is just crazy and a waste of money IMO.
Username: Deadrabit
Marionville, MO
Post Number: 1148
ac is for puss ies
get the 2nd alt
Username: Kingandsons07
TEAM REVOLUTION Lincoln,NE
Post Number: 404
mark that would be nice to have a 2nd alt.
and i all ways drive with the windows down. if its too hot just drive faster
i just wish it was worm here :-)
Username: Hittin1
Post Number: 2052
Twiz- It would be a daily driver, but it would also be a competition ride too. duhhhh lol
Post Number: 406
i would just love it as a daily :-)
