Rd 3250 question
Username: Wickedbass
Nashville, Tn
Post Number: 222
I have a RD 3250 that is running at 1.5ohms and was wanting to rewire the subs to .75ohms. Im pretty sure the amp would be okay at this load but was wanting to see what everyone thought first.
Thanks in advance for any help/advice you can give.
Wicked'
Username: Loudon
Post Number: 2834
with impedance rise ud be seeing right around 1 ohm
Username: Talon01
Team Revolution , Pa Usa
Post Number: 1881
your good i ran at .5 and was fine
Username: Andrew571
Post Number: 2155
u can .5 that b!tch daily son.
Username: Hittin1
Lake Charles, La. United States
Post Number: 1951
not gonna be a problem
Diamond Member
Post Number: 23095
is it not loud enough at 1.5ohms? just run it at 1.5. yes they can handle the low impedence but why put a strain on it?
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2557
I ran my 1750 at .35 daily lol.
Yes, it will be able to handle it with no problem.
Well Chad, with box rise you are looking at 2+ohm. That will make the amp put out half power. If he wired it at .75, it'll be 1+ohm after box rise. This does not put a strain on it, and it puts out alot more power.
Username: Hdubb
Team Revolution
Post Number: 3987
.35 daily on a 3250 isnt a problem as long as you have an eletrical system to back it up.
Diamond Member
Post Number: 23096
i suppose. good luck.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9204
With a stong amp like that it should not be a problem.
Unless you have a stock electrical in which case you shouldnt be running that amp at all.... well maybe at 4 ohms or somethin
Nashville, Tn
Post Number: 225
Thanks for all the input guys. I figured it would be okay but just wanted to be sure. I do have good electrical to back it up as well.
To answer your question Chad, no it isnt loud enough yet and I am hoping that some more power will get me a little bit more output from the subs. Hopefully I can do this without frying some coils.
Thanks again guys.
Username: Bonhamd
Traverse City, MI
Post Number: 1624
i havent had a problem yet - im running mine at .5
Nashville, Tn
Post Number: 228
Okay so I had a major brain f@rt (yeah apparently we can't say f art on here) when I made this thread. I have 2 subs with dual 1.5 ohm coils and I have them at 1.5ohms now but am wanting to go lower. What I thought would be a .75ohm load would actually be at .38ohms(I think?). Now I think I would really pushing my luck. I know this is a solid amp and I do have a really good electrical system but would this still hold up in a daily application? Thoughts?
Thanks again guys.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9214
I would not do that
Username: Tatonka
Post Number: 2561
That amp would take it with no problems if you have some charging system to back it up.
I have a friend who has my old sub and even runs his RD1750 at .35 daily with a stock alt and another battery. Voltage stays at 13+
Username: Nd4spd18
Philadelphia, PA
Post Number: 9217
It may take it but I still wouldn't put that kind of stress on one of my amps.
Username: Kingandsons07
TEAM REVOLUTION Lincoln,NE
Post Number: 387
i'm running mine .5 daily
Nashville, Tn
Post Number: 230
I really appreciate all of the input guys, yall are the best.
I think I will stick with 1.5ohms for now but I might try .38 later when I can ditch my yellow top for a 3rd hc2400.
Thanks again,
Wicked'
