Does This Work
Username: Rockets08
Post Number: 28
If my laptop doesn't have a RS232 port, will a USB to RS232 adapter work on the laptop instead of updating with the desktop?
Username: Laxey34
Miami, FL United States
Post Number: 62
I doubt. The uploader may not recognise the USB
Username: Laxey34
Post Number: 63
get a receiver with USB
check www.caritech.netfirms. com
Username: Plymouth
Post Number: 6512
Yes if you have the software with it.
Username: Bernardmi
Post Number: 301
Get this one from a reputable US company. It works. On all PC's and on all OS (win 95/98/NT/2000/XP and Vista)
http://www.iogear.com/product/GUC232A/
I recommend this to anyone. Guaranteed to work and be satisfying.
Username: Rockets08
Post Number: 29
Greggor:
Anyway to check if loader will work before buying?
Plymouth:
Would this be a better alternative since the other adapter came with no CD?
Username: Plymouth
Post Number: 6525
Ken
Do you have link?
You can buy The Outer Limits choice.
