Which FI subs
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2508
Ive been thinking latly about changing my system up and was wondering opinions.
Option 1:
2 12" Bl's with 1350rms each
Option 2:
2 12" BTL's with 1350rms each
Option 3:
2 12" BTL's with 2200rms each
I cant decide what to do. Ive currently got a zx2500.1 (2700rms) so it would be nice to keep that amp. But if i went the BTL route i would probly sell the zx2500.1 and get 2 AQ2200's. how much difference would be between the 2 12" Bl's getting 1350rms each and 2 12" BTl's getting 2200rms each?
Username: Bonhamd
Traverse City, MI
Post Number: 1622
i vote option 3 if you are willing to go through the hassle of selling your amp
if not - my vote would go to option 1 because it is cheaper
the BTLs have a stronger motor but with the cone area and power being the same, i dont think you would hear much difference between option 1 and 2
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3477
Do you have enough power to run 4-5kw? Its not as easy as people say... hah.
Id take (3,1,2) in that order if money wasnt an option and you had the proper charging.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9201
Well you're not gonna do option 3 without a HO alt and a few batteries.
So I say option 1.
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14547
most economical & sensible option wud be to keep ur good amp & do option 1
& if u want more sq than loud u can do 2 Qs instead of the BL...
Username: Snarl2004
Post Number: 2509
ive already got a HO alt and a hc2400 in the back. if i went option 3 ide get another batt for the back then moniter my voltage and decide if i needed another batt
Username: Nd4spd18
Philadelphia, PA
Post Number: 9208
while option 3 would be somewhat louder I don't think it would be enough to justify the cost.
Username: Snarl2004
Post Number: 2510
thats what i was hoping, for jsut a daily driver im hoping option 1 will work good
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 828
To me, based off your description, option 2 is the most logical. The BTL's will be plenty loud off 1300 watts, and louder (all things considered equal) then the BL's . No need to slam the BTL's with 2500 each for daily.
Username: Surferdude9371
Get loud or go home....
Post Number: 1566
id keep the amp and do one fully loaded blt 15 or 18 you have an s10 right? if so that will fit no prob
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2563
Go big.
Option 3 ftw!
Diamond Member
Post Number: 23110
quote:
originally posted by Nick V
Go big.
Option 3 ftw!
+1
Username: Th3pwn3r
I compensate...
Post Number: 9083
GO REALLY BIG AND BETTER!
DON'T BUY Fi SUBS!
Username: Talon01
Team Revolution , Pa Usa
Post Number: 1895
cant go wrong with some dc's
