Pansat 3500SD dead???
Username: Nsinha
Rochester Hills, MI USA
Post Number: 13
Folks,
My unit freezes with b-80 display...does not go any further. As such I am down with no channels. Is my Pansat dead? or is there is a solution to get this working. I do not think it is a problem caused by any bin file.
Appreciate any comments.
Username: Albino_midget
Post Number: 742
Try this with the latest or factory bin and loader 35.01 / null cable.
C/P
Turn the unit main power off and on (use reset switch) and click download within 1-2 second after LED display b-80. This download called boot method download. Some time click download first and then unit power off and on works better. Dot will move left to right during download completed.
If the unit display "ON" or any channel number, it means repaired as normal condition.
