Bronze Member Username: Skateguy92Post Number: 44 Registered: Jul-07 | I got a custom box made for my expedition for a couple 12's. I kinda wanted to keep it because it looks nice and I spend money/time on it but I can always use it later I guess. Anyways... I have a hifonics brutus 1500w (ya ya i know) and I was running two 12" type-R's. I want to upgrade and was originally gonna use two 12" RE SE's. Or I found a new RE SX 15" but it is a D4... So from my amp at max it would be seeing 1000w most likely 900ish but it would be clean 2ohm power at least. So, I was gonna ask for a few opinions on what to do. Oh and the budget is around $300-350 |
Gold Member Username: Logan__tillePost Number: 9128 Registered: Feb-06 | http://cgi.ebay.com/2-RE-AUDIO-SE12D4-12-SE-WOOFER-SUBWOOFER-SE12-D4-pair_W0QQit emZ200283081579QQihZ010QQcategoryZ18805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: LoudonPost Number: 2821 Registered: Jun-04 | ud be lucky to see 1k after rise and all other components ... go with a pair of lower rms subs if u have the space they are more efficient on lesser power |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14482 Registered: Jul-05 | unless u get a bigger amp i dont think new subs will sound much louder than what u have now ... |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2178 Registered: May-07 | Do you want to go louder or better sq? or both? |
Bronze Member Username: Skateguy92Post Number: 47 Registered: Jul-07 | both, I think ive got my plan figured out for my truck. Ive been sold on the RE SE woofer, so im gonna grab two of those for now and I plan on adding two more here in a few months around tax returns and a HO alt with 2500rms. Should get decently loud and sound really good. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5989 Registered: Nov-05 | i would not run two RE SEs on 2500rms.. if you plan to get that much power get the SX now and another later. you will sacrifice a little SQ |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14495 Registered: Jul-05 | ^x2 ... |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2190 Registered: May-07 | I think he's planning on running 4 total in the end. 2 now+2 later. 4 of those in a truck would be more than just descently loud. That would be an awesome daily setup imo! |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14497 Registered: Jul-05 | oh ok didnt know that - well then he can use those SE's but watch ur vol level - thats what im doing since i also have 2 10s SE's dual 4ohms running off my orion 2500d so i had to control the output by turning down the vol level on my cross over ... what i later did was wire the subs to 4ohms so it gets 1200wrms from the orion which im satisfied with ... |
Gold Member Username: Skibum12189Cleveland Post Number: 3021 Registered: Mar-06 | you could buy my 15" tc-3000 dual 2 ohm for a real nice price.... |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1560 Registered: Mar-07 | when did logan come back did i miss something? |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5992 Registered: Nov-05 | I am also running a pair of RE SEs.. great subs.. no where near the output of my old SXs tho.. much better SQ on the other hand... still get decently loud |
Bronze Member Username: Skateguy92Post Number: 48 Registered: Jul-07 | yup, just two for now and then two later around tax returns I think it will make a pretty nice DD. |
