RCA level controls?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9147
So i'm thinking about trying out one of these, something like this
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1770955/vpcsid/0 /SFV/30046
Anyone used it or know of any other good ones?
Username: Hdubb
Team Revolution
Post Number: 3977
use a PAC lc1 level control. awesome piece of equipment for daily and spl setup. spl you can use it to roll the volume so to speak much faster then just using the deck. imo id get it
Username: Wickedbass
Nashville, Tn
Post Number: 193
^^^Agreed
I've got pretty much the same thing but made by Hooker Audio.
This one.
They are very nice to have.
Username: Deadrabit
Marionville, MO
Post Number: 1126
i just ordered one last week. they look good to me and the one i got you can turn the RCAs off when it is turned all the way back
Username: Southernrebel
Post Number: 7158
I sell the Hooker Audio ones here at the shop. I love those little things, I hook up "smart" people that need a bass boost knob on there amp all the time. Yet to have a person blow their amp/sub w/ one of these. (But the same guys kill em w/ factory bass boost knobs :-))
Its true attenuator, much better than the 45hz boost from most factory ones.
Username: Insearchofbass
Post Number: 11046
Wouldnt the sub woofer control in the head unit do the same thing?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9148
Yep it is exactly the same thing but on a HU you have to usually go into the menu, select the sub control, and then adjust which is a pain.
Username: Hittin1
Lake Charles, La. United States
Post Number: 1875
"i just ordered one last week. they look good to me and the one i got you can turn the RCAs off when it is turned all the way back"
If hes gettin' one. I'm ordering two..
/thread
