Gold Member Username: DeadrabitMarionville, MO Post Number: 1115 Registered: Jun-07 | my freind said they are great. any one know much about it? |
Silver Member Username: DuckaHoughton and/or Macomb, MI United States Post Number: 853 Registered: Jan-08 | Get one and give it a review. |
Silver Member Username: QuirkySA, Texas Post Number: 367 Registered: Feb-07 | looks cool but seems like it would only be good for SPL competitions or short songs. It seems like the model 400 for $229.00 shows the capacity to be short lived; at 28.67 Amps = 5 minutes. However I don't know how strong 28 amps really are. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9124 Registered: Jul-06 | Crap..... i think the almighty glasswolf said it best "Another item I'd like to touch on is the more recent advent of the high capacity capacitors (25, 50, 100+ Farad capacitors) and so-called "BattCaps." These types of capacitors have extremely high ESR values which makes them very bad choices for the uses mentioned above. They are usually carbon-film based capacitors in order to get such high values, as opposed to the much lower ESR electrolytic capacitors you tend to find in teh 20 volt 1Fd type cylinder style units. End result is avoid anything like the 100Fd capacitors like a plague." http://www.glasswolf.net/papers/capacitors.html |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1118 Registered: Jun-07 | ya the caps dont seem like anything i would want to mess with. i emailed them about the 8400 battery. if i have to pay msrp no way i will get one. i can get stinger or kinetic pretty cheap. if i get one i would love to make a review but i really do'nt have anything to compair it to other than my small 800s. prolly woudln't be a good review |
Bronze Member Username: Joe_mustardHuntsville, Alabama United States Post Number: 13 Registered: Jul-08 | I've had a batcap now for about 2-3 years and it's definitely not worth much. Then again I have too much power running through it. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1122 Registered: Jun-07 | do u have a batcap or a batcap battery? |
Bronze Member Username: Joe_mustardHuntsville, Alabama United States Post Number: 16 Registered: Jul-08 | I have the batcap 400 |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1125 Registered: Jun-07 | a 400 is small. do u think it was good for the price? |
Bronze Member Username: Joe_mustardHuntsville, Alabama United States Post Number: 17 Registered: Jul-08 | Honestly, the only thing the batcap did for me that made things while was make it easier to hook things up in my trunk. I pretty much just used it as a distribution block. |
