Dish 300 Single slot 18" round DBS dish that can pick up programming from one DBS satellite location at a time. DBS locations for Dish are 61.5�, 110�, 119�, 129�, 148� and (not used) 157�.
Dish 500 A two slot 18" x 20" DBS dish designed to pick up 110� and 119� simultaneously. However it can be used to pick up 119� and 129� or just one satellite location like 61.5� or 148�.
Dish 1000 A three slot DBS dish designed to pick up 110, 119 and 129 simultaneously. This dish can be used to pick up 129� and 148� simultaneously.
Dish 1000.2 Slightly larger than a Dish 1000, its integrated head unit has 3 LNBs (110�, 119� and 129�), an input for a 4th LNB, and DP Plus switching to 3 receiver outputs.
Plus Dish 500+/1000+ Same as the Dish 1000 in function but about 5" larger and can pick up the 118.75� FSS location. As a 500+ it picks up 110�, 118.75� and 119�. Adding an LNB for 129 makes it a 1000+.
SuperDISH 105: Specifically designed to pick up 105, 110 and 119 121: Specifically designed to pick up 110, 119 and 121
This is the LNB for the new 118�W (Anik F3 / 118.7� / 118.8�) satellite. With this special LNB, you can get BOTH 118 and 119 at the same time!
Works with both Free-to-Air and Original DN Receivers!
Requires: 30-inch or larger dish Compatible with DirecTV, Free-to-Air (DiSEqC, 22KHz), and legacy switches (SW21, SW44, etc) Not compatible with DishPro switches and/or DishPro (stacked) LNB's
SPECS Polarization: Circular Input Frequency: 11.70 - 12.75 GHz LO Frequency: 10.750 GHz Noise: 0.5 dB
Dual-output (ready for 1 or 2 receivers)
SETUP INSTRUCTIONS Using a 30-inch or larger dish, aim with the following settings:
Satellite Name: 118�W (Anik F3) or 119�W (Echo7) LNB Type: Standard (or Single) LO Frequency: 10750 or 10600 MHz Finally, do an AUTO SCAN or a BLIND SCAN
For some the following settings may work better or give you more channels:
LNB Type: Universal LO Frequency: 9750 MHz HI Frequency: 11750 MHz
ALTERNATIVE SETUP If there are any missing channels, MANUALLY scan them in. You can refer to the channel list at Lyngsat.c*om
You may also load this satellite using SharpC's Channel Master program.
A) Scroll to Edit TP/Satellite press (OK) B) Scroll to bottom you will see the word NEW press (OK) C) On this board highlite one character at a time and press (OK) when you finish entering these characters, if it looks like this Anik F3/Ku ..press (OK)should be at the bottom next to del. next you will see this.
Down Frequency Symbol Rate Polarity
Pull up.....http://www.lyngsat.com/anikf3.html here you will find all the TPs for Anik F3. If you don't have a HD Receiver don't bother entering the TPs outline in green.
I will post the first TP for you. Down Frequency....11715 Symbol Rate...20,000 Polarity V
You have d*sh 1000. You can get a Repoint Kit from e*---Bay. The lnb looks like an eye. Also, you have to move dish a lil towards left and try to get max signal quality. Rescan channels.
