Adding A Battery?
Username: Raydizzle34
Post Number: 11
Hey all,
I have installed the Kenwood KDC-X492 head unit, Kenwood KAC-9104D amp, 4 Kenwood KFC-C6882ie speakers, and 2 Kenwood KFC-W3011 Subs in my Ford Ranger.
I like to listen to my music loud and the bass hits pretty hard but my headlights and instrument panel lights dim when the bass hits and I wanted to ask you guys if I added another battery to my truck if it would help get rid of this issue.
I also plan on adding another 4 channel amp for my speakers in the future.
If the battery would help, would I be able to just wire it into the existing electrical or would I need to dedicate the whole audio system to it?
And finally how would I go about putting the battery in wiring-wise?
Thanks guys!
-Ray
Username: Kissdaredevil
Post Number: 58
get a H.O. alternator, or add a second alternator and run a second battery off that.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9389
HO alternator would be the solution. However, most everything kenwood makes is not very good.
Their amps are terriably inefficient. Better amplifiers that draw less current may be the only fix you need.
Username: Twistedmetal214
San jose, California
Post Number: 8
yeh m.s is right but all you really need to do is buy a good Capacitor....that will make sure all the power from the battery is evenly distributed amoung the car.........that will solve your problem
Username: Erbgottie
M-Town, Upper Cackal... US
I have a Rocfkord T2 15 hooked to a T10001BD amp as well as 4 RF 6X8's hooked to a RF T400.4 amp and a pair of tweets hooked to a RF T200.2 amp in the '04 ranger. I put in a HO 200amp alt and added a Stinger dry cell and I've had no problem with lights dimming at all. Also, the BIG 3 is done and prob helps more then the rest of those upgrades. I like my music loud too and it gets loud as hell w/o that dimming BS.
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2248
"all you really need to do is buy a good Capacitor....that will make sure all the power from the battery is evenly distributed amoung the car.........that will solve your problem"
1. Capacitors are usually just a waste of money.
2. "Amoung" is not a word.
With the amount of power you are running, try upgrading just your stock battery and doing the Big 3. If that doesn't work then do a H.O. alternator.
Anyone disagree? (mainly asking m.s. since he is better with electrical)
What year is your ranger? Do you know what size alt you currently have?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9395
Lmao that alex guy could not be any more wrong.
Either get the alternator + battery or get better amps...... I'd get a good amp first.
Post Number: 13
Thanks for the info...
I have a 2000 Ranger w/ a stock alternator and I replaced the stock battery last year with one of the same rating. (It was before I put the system in)
Thanks!
Username: Staffsgtspaz
I just started a system and I have the main power to the 2 10' kickers with a big marine battery in the trunk. Its best to use a seperate power supply becouse it will take less strain. In other words, if you hook it to the car battery itself, it will be starved of its potential peaks. A seperate battery gives it all the juice it needs and all you got to do is charge it every now and then. A new battery is the best way to go.
