TREO SSX or Fi BTL???
Username: Boston_spl
Highland, CA United States
Hey guys, I'm planning on upgrading my current sub setup: (Kicker CVX 15" dual 2ohm running off a Crossfire vr1000d at 1ohm) to either two Treo SSX 15's or two Fi BTL 15's. My local shop, which is an authorized dealer, will sell me two SSX 15's for $1000 out the door. And I looked at Fi's website, and the BTL's are $470ea. with the configuration I want. I'd also appreciate any advice on an amp or amps. I'm considering either two US Amps AX2000 or two Zapco 9.0x. This setup will be in a '96 Chevy Caprice Wagon. I'm running an Alpine IVA-D300, Crossfire vr354, and Diamond Audio D651s components off a stock battery and alternator, if it helps. I realize that this much of an upgrade will require a charging system upgrade, so any advice in that area would be great. Thanks.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 6238
Treo SSX and buy mine its a beast!
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3444
SSX 15s and Zapco 9.0s :-)
Would the SSX be capable of producing the same SPL as the BTL? From what I've herd the BTL is pretty much a straight SPL sub, where as the SSX is more of an SQL sub that's very capable of producing sum good SPL. Does this sound right?
Also, I often listen to my stereo with the engine off, so when I get these 15's how should I upgrade my electrical system? Battery/ Alternator recommendations, etc.?
Post Number: 18
Any advice guys?
Username: Ducka
Houghton and/or Macomb, MI United States
Post Number: 830
big 3, HO alt, a second battery... You may be able to get away without doing all of those, just keep an eye on your voltage.
Username: Hdubb
Team Revolution
Post Number: 3964
big 3, alty, and id say for daily id go with 2 batts in that back and a good one under the hood. the btl isnt a bad driver. im not too big of a fn of how they sound, the ssx i think is a much better bet, but 500 a piece is a lot of money.imo.
imo go kicker hyperflex 0ga, a mechman alty,and either powermaster bats or odessey 2150 (stinger bats is the same) or if they arent in your budget go deka. or northstar nsb90s.
Post Number: 19
What amperage alternator should I get?
Are Kinetik batts. any good?
Also, if I get 2 backup batteries, what size batteries should I get? Other than an isolator, what else do I need to install them (like getting an even higher amperage alt. to compensate for the charging of the two extra batts.?)
I assume with the H.O. alt. that a capacitor would be pointless? (As capacitors often seem to be anyway.)
Username: Stnorris
Fully Loaded BL 15?, IA US
Post Number: 2246
kinetik batteries are really good, but i would say get something else due to the fact they are sh**ty to hook up and also i have heard things about the kinetiks being overcharged. I read you are not supposed to let them charge over 14.3v or they will eventually fry. I have one and charge it around 14.7 and 14.8 all the time...it seems like its losing some of its potential...someone else might know more about this..
Username: Dustin3
Tigard, OR U.S.
Post Number: 4859
why not 2 15" BL's? I would only get 2 15" btl if i were looking to compete.. for a daily driver IMO its a little overboard.
Post Number: 21
You're probably right about the BTL's, plus I'm looking for a bit better SQ than I think the BTL's can provide. What is a good price for SSX 15's?
Also, how good of an SQL sub would the AudioQue HDC315 be? It would be nice to only spend $500 on two HDC3 15's, though for a little more SPL I'd be willing to spend more, then again I've never herd the AudioQue's, but I really liked the SPL & SQ of the SSX's.
Lastly, would one AQ2200D per SSX, or one AQ2200D for two HDC15's be a good match?
Oh, and any recommendations on H.O. alt. amperage before I buy one? Looks like I'll be pushin' about 5000w at the most for subs and about 200w or so for components, if it helps. Thanks guys.
Post Number: 23
Hey, are Odyssey and Stinger batts. literally the same thing?
Username: Dlavante
Tigard, Or USA
Post Number: 119
two HDC15's with an AQ200D would slam and still sound fairly decent. you cant really beat the hdc3's for the price imo. as for the alt i wouldnt go any less than 260 amps.
Username: Dlavante
Tigard, Or USA
Post Number: 120
oh my bad you said 1 AQ2200 for both HDC3's.. why not one for each??
Username: Th3pwn3r
I compensate...
Post Number: 8987
I think I'd go with the SSX. I'm not a big fan of Fi products. Scott is an off guy...
Post Number: 24
Good question Daniel, how much $ do the AQ1200D & AQ2200D go for?
Oh, and any idea as to what size (volume) of a box I'd be lookin' at for each HDC315 for SPL (ported)?
Post Number: 26
I looked on AudioQue's site, but I couldn't find amp prices. Hopefully they're less than Zapco comp. prices.
Post Number: 27
Anyone know the prices?
Username: Ducka
Post Number: 843
http://www.audioque.com/aq/order.htm
Post Number: 30
Awesome. Thanks.
BTW, that seems pretty damn cheap.
Username: Bonhamd
Post Number: 1561
I like the SSX quite a bit
"I think I'd go with the SSX. I'm not a big fan of Fi products. Scott is an off guy..."
why is that rob??
Post Number: 37
Anyone know how much Treo SSX15's run $ new? Not online, but in a store.
Username: Kingandsons07
TEAM REVOLUTION Lincoln,NE
Post Number: 356
look in too rd alpha's. everyone on here so far really likes rd audio. chad being a big one lol but there's better then audio Q and FI....
Post Number: 38
I'll do that. Thanks Quentin.
