6.5s powered by deck
Username: Talon_es93
Trinidad, Co
Post Number: 848
what are the best 6.5 components i can power with a deck to put into a 02 tahoe... i'd say under 90$.. and if i hae a choice in that price range i'd like for the tweeters to be pretty bright
Username: The_image_dynamic
San Diego, California
Post Number: 4876
Someone said the Phoenix Gold comps work well with HU power.
Trinidad, Co
Post Number: 849
ya i heard that to. the ryval series right?
Username: Insearchofbass
Post Number: 11024
Up your budget a tad and go with the cdts. $99.99 shipped from woofersetc on ebay. I really liked how they sounded off the deck and the tweets are on the bright side.
http://cgi.ebay.com/CDT-Audio-CL-S60A-TW-25-6-5-2-Way-Component-Speakers_W0QQitemZ110312472612QQcmdZViewItemQQptZCar_Speakers?hash=item110312472612&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Username: Nd4spd18
Philadelphia, PA
Post Number: 9103
I would have to disagree with the CDT tweeters being bright...... the are more neutral. (in a good way)
And definetly those over the PG.... I was not impressed with the PGs at all.
Trinidad, Co
Post Number: 851
elich would be best between the PG.... PB s6c...mb quart fsa 216 ... and kicker ds600s
Username: Shade
Moxee, Wa U.S.
Post Number: 822
PG RSD's 6.5
tweeters are bright and it don't take much power to get them going....if u shop around u may find 2 sets for that price.
Trinidad, Co
Post Number: 852
those would have the brightest tweets out of these listed?
Post Number: 11028
"PG RSD's 6.5
tweeters are bright and it don't take much power to get them going....if u shop around u may find 2 sets for that price."
If they are bright then the cdt's I recommended definitely are. The rsd 6.5's are the ones M.S. and I heard and ill tell you the cdts are better than the over hyped rsd 6.5 components.
Trinidad, Co
Post Number: 853
but will cdt sound pretty good on just my stock deck?
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14496
i would rec comps rated around d 50wrms - anything from DLS is very good ... but why dont u get a small amp , it shouldnt be that much $ ......
Trinidad, Co
Post Number: 854
i just dont want to deal with all the wiring..and i'm keeping my stock deck so i would run into problems with the RCAs.. i would like to change it out but its to pricey b/c of the onstar
