Bringing Subwoofers inside
Username: Afroopuff
Post Number: 499
I have heard of people taking their subs from their car and bringing them into the house for a little more. Is this bad for the sub at all? If it is firing without an amp and just being powered by speaker wire out of the TV?
A pic is worth 1000 posts!!
Post Number: 19271
You mean free air?
It would be waaay underpowered as well.
Would sound like poo.
Username: Afroopuff
Post Number: 500
not familiar with the free air termonology... if you mean without a box, no i would leave it in the ported box from the car. No amp though correct...very underpowered...but worth it? does it hurt the sub?
Username: Jtown
Texas
Post Number: 3370
you can buy a home theater plate amp or it is possible to power the subwoofer through the receiver, if you have one
Post Number: 19274
Won't hurt the sub but why? Most speakers in any tv are full range and 25w or less? You'd be left with only hearing the lows. Crappy sounding ones at that.
It would be like watching tv with ear protection on.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9107
You could run one on a home audio system with a plate amp
If it can be wired to 4 ohms that is
Username: Bumpndatrunk
Milwaukee, WI
Post Number: 262
I hooked up my subs to my home stereo b4 but it was some low end pioneer subs they hit ok and there are some subs like the soundsplinter that are made for home or car use so i say go for it
