Bronze Member Username: LabsPost Number: 25 Registered: Oct-06 | please help. 61.5 indian programming not working. loaded new bin already. pansat 2700a with b75 v201 femu. what should i do |
Platinum Member Username: NydasPost Number: 13571 Registered: Jun-06 | https://www.ecoustics.com/electronics/forum/home-video/534834.html zak michael said: 'idid factory reset so after factory bin so just choose language option was up then loaded the v201 , then chose english, then blind scan and i got everything back full list and a few i was missing.' I will add that you will have to set up the Antenna setups for scanning before you can scan. |
