Brakes for a tahoe on 24s?
Username: Talon_es93
Trinidad, Co
Post Number: 857
would a 02 tahoe need a brake upgrade with 24"s?
Username: Bonhamd
Post Number: 1560
i would definately upgrade brakes for 24s
Trinidad, Co
Post Number: 858
sounds to me like it would need them to but just to make sure.. i have an uncle with 24s on a navi and he didnt upgrade and it stops fine.. id like to hear what someone with 24s on tahoe has to say
Username: Bonhamd
Post Number: 1565
i have never had rims but you are going from 16s to 24s
im sure plenty of people dont upgrade brakes - but it probably is a good idea
berny could probably give you some good advice
Username: Livin_loud
COD4 Addict
Post Number: 2790
it doesn't make a difference what vehicle it is. weight is the only variable, and a large suv will definitely need an upgrade. his brakes won't last long. they also probably don't match up with the rims very well either...
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4493
I've got an 02 escalade with 24s and stock brakes.... I really do not need a brake upgrade. Of course different wheels have different weights and I'm not sure if the escalade has different brakes than the tahoe.
Trinidad, Co
Post Number: 859
i would think they do have the same brakes... everyone always says its all the same sh!t just different emblems.. and i asked my uncle and he said the navi came with good size brakes wich is why he didnt change em...and i tried to google an answer before comming here and i read that the acual weight don't matter... its the bigger diameter that makes it harder to brake... but if weight does matter its ok b/c i don't like filled in rims.. i like basic thin 6 spoke wheels with deep lips like the U2 55 series
Username: Bernymac
Phnom PenhCambodia
Post Number: 4487
Definitely upgrade. I have 22's on my Yukon and it brakes just fine. I have a friend with 24's on his nbs tahoe and it doesn't stop as well as mines. Maybe it might be due to the fact that my setup was recently "fixed" and my mechanic did one hell of a job on my braking system.
Username: Killerzracing71
Post Number: 2347
I wouldnt worry about it, Upgrade the pads if anything not rotors
Not worth it.
Unless your going racing
Just treat your car like it has 24s and not the factory 17s or w/e it had.
Of course its gonna brake longer, its more Rotational Mass, takes longer to stop.
BTW i have 22s and it breaks better then I thought I had to slam on them and it slowed down REALLLLL QUICK.
Username: Joebruce
TC Sounds/DLS
Post Number: 2489
Nuff said :-)
Username: Nd4spd18
Philadelphia, PA
Post Number: 9119
^^^ haha good stuff
On another note I would never do any "upgrade" to a vehicle that REDUCED braking performance.
Trinidad, Co
Post Number: 860
do you have a huge sound system?? i'm sure that would do the same if your running lots of batterys and big azz 18" subs in like 5 cf. each
Username: Nd4spd18
Philadelphia, PA
Post Number: 9127
I have 2 Fi Q 10"s and one good battery tyvm.
It kills my brakes.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3453
I upgraded my brakes on my mountaineer when i went from stock 17s to 22s and there was a HUGE difference. I personally would upgrade the brakes going to 24s... If your going to upgrade do it right.
Trinidad, Co
Post Number: 862
kills your brakes uh lol.. ya i just don't want to deal with having to upgrade them.. so if i'd have to. to get 24s then i'll drop to 23s or 22s.... or 13" daytons ;)
