Bronze Member Username: AlftabinPost Number: 63 Registered: Dec-07 | 2700 bin is out |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 831 Registered: Mar-07 | FU |
Platinum Member Username: NydasPost Number: 13460 Registered: Jun-06 | The new 2700A BIN is out and IT IS A FULL EMU VERSION 201 [link removed] |
Bronze Member Username: AlftabinPost Number: 64 Registered: Dec-07 | Nalin, what does "full emu" means? It is not working for some reason... |
Bronze Member Username: Hockeycraze12000Post Number: 15 Registered: Nov-08 | Is there PUFF out yet? |
Platinum Member Username: NydasPost Number: 13463 Registered: Jun-06 | For 2500/FLU converted: There IS NO conversion BIN yet. Wait for the proper BIN. Also do NOT use trnics direct installer for 2500/FLU. WAIT for PUFF BIN. WAIT for PUFF BIN. |
Bronze Member Username: Hockeycraze12000Post Number: 16 Registered: Nov-08 | OH MY GOD, FULL EMULATION. EMU=Emulation. To emulate or too imitate/copy/act as the cards used in subscribed receivers.If this can be done 100% I can't think of what they could do at that point that would affect only fta receivers. But I'm no coder.Perhaps bins never can 100% fully emu a subbed card.I only say this because it hasn't been done yet,so until then its unknown. And how much flash rom size does it take to have full emu? We will just have to wait and see. But if it did,your fta receiver would not see keys roll anymore I don't think as it would just think it was a subscribed card. BUT then is the next question.If this 100% full emu does happen,will the providers then do a card swap? Can they afford it? What would stop coders from making a new full emu (with time of course) of the next card? Time will tell. Its fun to watch how it plays out,how,if,when coders will do the full emu. |
Bronze Member Username: Hockeycraze12000Post Number: 17 Registered: Nov-08 | How long do you think it will take for PUFF, I want to do it tonight. |
Platinum Member Username: NydasPost Number: 13465 Registered: Jun-06 | In the latest full EMU BIN 201 for Pansat 2700, a lot of memory location will have changed. Therefore, DO NOT expect a PUFF BIN soon. It might take the coders 2-3 days to figure out the right locations and make changes for conversions. |
Bronze Member Username: AlftabinPost Number: 65 Registered: Dec-07 | Nalin, why bin 201 not working? |
Bronze Member Username: 3dgesCompton Post Number: 90 Registered: Feb-08 | When do you think the next b-75 will be out |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 833 Registered: Mar-07 | alftabin, I apologize for my post above. I confused you with this spamming moron: https://www.ecoustics.com/electronics/forum/home-video/534438.html Sorry. |
Bronze Member Username: AlftabinPost Number: 66 Registered: Dec-07 | It's ok ![]() |
Platinum Member Username: NydasPost Number: 13467 Registered: Jun-06 | The full EMU version 201 for Pansat 2700A/E is a different type of BIN. I expect a lot of memory locations will have changed. The conversion coders are used to seeing a certain memory pattern at certain locations and make appropriate changes. In fact Tronic has fully automated this process. however, with then new BIN, these coders will have to work hard to detect the changed locations and code to be changed, so they will take longer - whether for b75 ot PUFF conversion BIN. |
Silver Member Username: BorinickPost Number: 464 Registered: Mar-07 | what's full emu means |
Platinum Member Username: NydasPost Number: 13469 Registered: Jun-06 | Full EMU means full emulation (full copy) of the original ROM in the official DN receivers. It is easier to keep track of changes and recover from ECMs. Up till now we have been relying on functional copy of the original, now we have both an exact and a functional copy. Usually the full EMU version takes up more memory. This BIN is only 896K bytes long unzipped, so it will be amenable to PUFF compression |
Bronze Member Username: AlftabinPost Number: 67 Registered: Dec-07 | Ok, how to use it? |
Gold Member Username: Dude123Post Number: 2387 Registered: Jul-06 | Full EMU file working great on my 2700 CONFIRMED!!!! |
Gold Member Username: Dude123Post Number: 2388 Registered: Jul-06 | flash your receiver the way you usually do...its working |
Bronze Member Username: AlftabinPost Number: 68 Registered: Dec-07 | I did. It still shows "scrambled..." |
Silver Member Username: MzakcatPost Number: 110 Registered: Aug-05 | my echo 7,s are scrambled???? 110's are open |
Silver Member Username: MzakcatPost Number: 111 Registered: Aug-05 | nw are your 119's up if so whats your disceq settings?? maybe i need to match emu |
New member Username: OusuPost Number: 9 Registered: May-06 | Loaded the new bin as usual, but it is still scrambled do we need to do somthing else? |
Silver Member Username: MzakcatPost Number: 113 Registered: Aug-05 | Ousu and Alfta are you guys scanning 110 and 119 or more |
Bronze Member Username: FatbackPost Number: 50 Registered: Jan-08 | mine is the same way-no echo7 just scrambled channel.tried doin a blind scan but progress stopped at 55% on echo 7 |
Silver Member Username: MzakcatPost Number: 115 Registered: Aug-05 | bevis is your 119 disceq 1.0 #1 110 disceq 1.0 #2 |
Bronze Member Username: FatbackPost Number: 55 Registered: Jan-08 | no-mine are on 3and4.thats where they have always been and ive had no problems-could it be an issue? |
Gold Member Username: Dude123Post Number: 2389 Registered: Jul-06 | I am on 148 and its still working perfect...No bugs atall... |
Bronze Member Username: FatbackPost Number: 56 Registered: Jan-08 | would it hurt to try loading it again? |
Gold Member Username: Dude123Post Number: 2390 Registered: Jul-06 | Just loaded the way I usually do and its all up and running didn't even search for keys. As soon as the file was downloaded it went straight to the channel. You shouldn't have to do anything different...Well atleast I didn't have to do anything different. |
Gold Member Username: Dude123Post Number: 2391 Registered: Jul-06 | nope...try again and see if it works |
Bronze Member Username: AmitnfPost Number: 14 Registered: Oct-07 | not getting international channels from 61.5 |
Bronze Member Username: OusuPost Number: 11 Registered: May-06 | Loaded it twice the usual way blind scanned turned off and on nothing !! Scrambled |
Bronze Member Username: Arthur22Post Number: 21 Registered: Feb-08 | same thing happened to me,1*10 is good and I am missing 1*18.7 and 1*19, any idea or we have a bad bin? |
Bronze Member Username: Arthur22Post Number: 22 Registered: Feb-08 | same thing happened to me,1*10 is good and I have no signal on 1*18.7 and scrambled 1*19, any idea or we have a bad bin? |
Bronze Member Username: OusuPost Number: 13 Registered: May-06 | good night Let's see if anyhting new comes out tommorow |
Gold Member Username: Dude123Post Number: 2393 Registered: Jul-06 | As I said, I am on 148W and its working perfectly fine all international are working good so i doubt that there is going to be a new one coming out tomorrow. |
New member Username: BaalbeckiPost Number: 8 Registered: Oct-06 | BIN PANSAT 2700 is out.. Go to dishkeys dot co dot nr |
New member Username: RkrMontreal Post Number: 9 Registered: Mar-08 | any new b-75 bins for fortec ultra lifetime |
Platinum Member Username: NydasPost Number: 13521 Registered: Jun-06 | Rukesh: None so far. |
