What is all the ado with the new Puff file?
Username: Jwl1
Post Number: 339
After reading, I thought this was going to be quite a task with problems, and maybe even failure.
However, I see nothing different! Other than the way it's loaded. Everything else functions just the same after the load and rehook up. The picture comes right up, just as it did.
Of course, you can't turn it off from the back to do a reset as before if you have some issues, from what I understand.
