AQ and other subs with wires
Username: Deadrabit
Marionville, MO
Post Number: 1103
ok now i don't knwo what these things are called but on my aq subs i had to solder the wires from the sub with my wires going to the amp other than having like a push button thing to put my wires in.
i am really wanting to be able to get something like that so i can change the ohm load for comps to daily.
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 3113
LOL. Wire nuts ftw. Solder is not very conductive.
Username: Deadrabit
Marionville, MO
Post Number: 1104
AHHH! that is what they are called!
i am lookin on ebay. not seeing anything good
Post Number: 3116
Just take a trip to your local hardware store. They're not hard to get.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9112
" LOL. Wire nuts ftw. Solder is not very conductive. "
I hope that was a joke but i don't think so.....
A soldered connecton is superior to anything else.... but not practical in this case..... the best thing for this are "quick disconnects" from radioshack. They crimp on the wire and you push them together. Makes a secure connection and you can literally change connections in a second.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9113
http://www.radioshack.com/product/index.jsp?productId=2104020
Username: Deadrabit
Marionville, MO
Post Number: 1105
those look like it would be hard to use again after you have used them a few times.
i was looking for somehthing like this but bigger http://cgi.ebay.com/88-2-WIRE-NUTS-153-4-POSTS-NUTS-4-LIONEL-OTHERS-5ct_W0QQitem Z110321968390QQcmdZViewItemQQptZModel_RR_Trains?hash=item110321968390&_trksid=p3 286.c0.m14&_trkparms=72%3A1240%7C66%3A4%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A 1%7C293%3A1%7C294%3A200
Post Number: 3118
Sure soldering would be the superior connection if you're using the correct solder and actually know how to solder correctly. But in this case, you can't beat a direct copper on copper connection using wire nuts with some electrical tape wrapped around. It will be far superior to a shitty crimp job using male/female disconnects and also doesn't take that long to remove and rewire.
Username: Bonhamd
Post Number: 1557
i would just get wire nuts from a local hardware
Username: Deadrabit
Marionville, MO
Post Number: 1114
what about these?
http://cgi.ebay.com/Wago-Lever-Nuts-Wire-Connectors-28-12-AWG-2-Pole-Bag100_W0QQ itemZ300274729130QQcmdZViewItemQQptZBI_Connectors_Switches_Wire?hash=item3002747 29130&_trksid=p3286.c0.m14&_trkparms=72%3A1240%7C66%3A4%7C65%3A12%7C39%3A1%7C240 %3A1318%7C301%3A1%7C293%3A1%7C294%3A200
Username: Livin_loud
COD4 Addict
Post Number: 2795
audioque.com/aq/leadwire.htm
Username: Deadrabit
Marionville, MO
Post Number: 1116
thanks man
Username: Nd4spd18
Philadelphia, PA
Post Number: 9123
" those look like it would be hard to use again after you have used them a few times. "
Umm no they're definetly not
" It will be far superior to a shitty crimp job using male/female disconnects "
Because crimping a good connection is hard......... or not. I use those everywhere I need a removable connection.
Post Number: 3127
^^ I've used them for my components and many other things. I still don't like them. Just whatever floats your boat, M.S.
Username: Hittin1
Lake Charles, La. United States
Post Number: 1853
http://www.radioshack.com/product/index.jsp?productId=2104018&retainProdsInSessi on=1&numProdsPerPage=60
may need the yellow ones depending on wire size
Username: Nd4spd18
Philadelphia, PA
Post Number: 9133
You mean the ones I already posted the link to? Yea he would need those.
Username: Deadrabit
Marionville, MO
Post Number: 1128
what something like this but smaller?
http://cgi.ebay.com/STINGER-SCOUP0-COUPLER-1-0-GUAGE-POWER-WIRE-TERMINAL_W0QQite mZ310105752782QQcmdZViewItemQQptZCar_Electronics_Installation?_trksid=p3286.m20. l1116
