Do I Got Enough Juice
Username: Comerz
Post Number: 159
last year I was running my 12 alpine type R and hifonics amp taking up 600 RMS. I recently installed dimaond audio comp speakers with a kicker amp using up 350 RMS. Now I havnt used these 2 together because I need a new amp for my sub, (long story). I have played the comp speakers alone and works fine, same as the sub did.
Now my main concern is will my 94 toyota corolla support the power needed for both these setups using a combined 950 watts RMS?
thx for any help.
Username: James1115
Use a simple...
Post Number: 10716
how many amps is your alt?
run it and see, if you get severe light dimming then you know you need a new alt.
Username: Cozce
St. Louis ILLsideU.S.A.
Post Number: 422
Find out how big your alternator is then get back to us.
Username: Th3pwn3r
I compensate...
Post Number: 8975
Try it. It'll work but remember you don't have to turn the volume dial to max, the same goes for the gains on the amp. Use what your electrical system will allow you.
Username: The_image_dynamic
San Diego, California
Post Number: 4868
The 1.6 liter has a 70 amp and the 1.8 liter has an 80.
Username: Comerz
Post Number: 161
it is a 1.6 litre with a 70 amo fuse. So do you think it will still run this fine? :/
Username: Comerz
Post Number: 162
Im also wondering, would i be able to take a 1.8 litre altenator out of the same year corolla (80 amp) and put it into my 1.6 litre without any problems?
Cuz i think im cutting it awefully close with the 70 amp altenator.
Username: Surferdude9371
Get loud or go home....
Post Number: 1558
an extra 10amps wont be worth the money or the time imo id save up for a HO alt until then run your gains responsibly
Username: Comerz
Post Number: 163
so back to square one, do i really need yo get an altenator, i just want to get the same amount of bass i got before, jsut with the upgraded speakers now taking an extra 350 rms. Will i get this performance still?
Username: Livin_loud
COD4 Addict
Post Number: 2786
grape, apple, orange or other?
Username: Stateprop486
PA
Post Number: 1721
should be fine, i was runnin a kicker zx1000.1 on my stock 80amp alt in my 1999 camry. never had a problem at all. that amp produce more then 1000 watts too.
