Wiring question?
Username: Turnmat
Racine, Wi
Post Number: 813
I have three dual 4 ohm speakers. so if i wire them all together i can wire them down to 2.67 ohms. My amp is the pdx 1.1000. I know the amp is a mono amp and it has two slots for subs.
My question is should i wire the subs to 2.67 ohms and only use one slot for the subs or should i wire two subs together for the one slot and wire the other sub for the second slot? Will it make much of a difference which way i do it?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9074
no difference
Username: Hittin1
Lake Charles, La. United States
Post Number: 1832
no difference at all.. they(all 4 speaker outputs) are internally paralleled
Username: Turnmat
Racine, Wi
Post Number: 815
ok. thanks for the help
