Cheap first setup
Username: Tpizzle
Post Number: 547
Im looking for sub/amp recommendations for a 2003 stratus. I listen mostly to rap and rock and just need something that will hit hard. I am either thinking two 10's or one 12. Hope to keep the combo under $250, thanks for the help
Username: Nd4spd18
Philadelphia, PA
Post Number: 9075
Thats a very low budget but you can make it work.....
I'd prob go with a Kicker CVR and ZX400.1
Those plus a wiring kit will put you at budget
Username: Surferdude9371
Get loud or go home....
Post Number: 1545
cvr's are great for the price and for a first setup
Username: Imalik
15 SI Mag9.1=Boom, New Jersey Jerzee Playa
Post Number: 631
I would deff get the 12" CVR..you can save a bit of cash by putting it in a sealed box(pre fab) since your on a budget
Username: Nd4spd18
Philadelphia, PA
Post Number: 9078
Yeah a prefab is ok if it's sealed and made from 3/4" MDF
Username: Boston_spl
Highland, CA United States
Post Number: 17
Agreed.
