How smart are u
Username: Jason420
PIMP CITY, GA USA
Post Number: 23
lets say i have 2600rms amp what will i need to power it {wires,battery,h o alt ,anl fuse }
Username: Livin_loud
COD4 Addict
Post Number: 2780
i'm not smart enough to answer such a question, sorry.
A pic is worth 1000 posts!!
Post Number: 19234
Big wires. Like really big. Bigger bat. Like really really big. Bigger alt. Like really really really........................................................
Username: Surferdude9371
Get loud or go home....
Post Number: 1548
2 batts 200 amp alt 300 amp fuses
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5977
for some reason i think your referring to a hifonics amp and it don't do 2600rms.
Username: Shade
Moxee, Wa U.S.
Post Number: 818
1/0g, big 3, 200a alt, 1 big battery in back...keep ur stock upfront, 300a fuse
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2174
What amp and vehicle are you using?
Are you competing or is this a daily driver?
And why are you asking us this question? Sounds like you know what you need judging by your profile...
Username: 04redmach1
Es DEALER, GA USA
Post Number: 2462
This Kevin agrees with other Kevin. Kevin is pretty smart and this Kevin is thinking Hifonics too. Are we correct?
Kevin
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14481
0g wire
cant be any harm getting the biggest alt which can fit in ur ride - also a 2nd batt is nice to have so u can play ur tunes with the engine off ...
Username: Tejcurrent
Post Number: 1626
I would get a good alt that does 150+ at idle and 2-250 at hwy.
One run of 1/0 should carry the power fine, but a 2nd is always a plus.
One nice extra battery in back would probably cut it.
MLA module.
Fuse size depends on the amperage the amp will pull and if you have other amps like a 4ch or something else. I like to use a 250 for each run of 1/0 and then the size fuse I'll need in the run from the rear battery to the amp.
Username: Jason420
PIMP CITY, GA USA
Post Number: 25
yes it's a hifonics i was trying to see if i need any more upgrades to my car thank-u for the advice ...by the way do u think my system will really drop very low}check my profile
Illinois Braaap MX
Post Number: 2179
If by drop low you mean low voltage, then you should be fine assuming it is installed correctly (as far as good grounding, etc.) Especially if you are only running that amp @ 2 ohms.
