Bronze Member Username: Markdavid
Post Number: 41 Registered: Feb-07
Posted on Hello , I would like to know the difference between the Passive Pre amp and Active Preamp , which one is better and why? This is for my Quad 99 power. thanks in advance mark. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13184 Registered: May-04
Posted on . MW - Did you ever try a search engine? Or looking through the archives? Active means the device has active circuits, it plugs in and has a power supply. Passive doesn't. Which is better depends on your system and your set up. Get out of the "Amps" section and look in the "Pre amps" section for a discussion of the two devices. . |
