My new system
Username: Fish5
IN
Post Number: 38
I'm wanting to get two 12" subs probably FI SSD's, but i'm not sure what options to get on the FI website? I mainly listen to rap and rock, and am looking for sql. I plan on going ported, probably to 33Hz (w/ a fishercustoms box). I plan on getting a Sundown SAE1000. With this being my first set-up, I just want to make sure that i'm getting the best stuff possible. I already have a hu and speakers, i just need some subs. I'm open to other subs, but would like to stay w/ the sundown amp as I already have one and am really happy with it. Altogether, I'd like to stay below 1000$. Any advice wold be great! thanks
Username: Mmaudioconcepts
Post Number: 597
fully load it, it wont hurt and they will be easier to sell in the future. If u plan on keeping. since you are running two amps, get the dual 2 ohm, flatwind, bp power
Username: Livin_loud
COD4 Addict
Post Number: 2764
sounds like a solid first system. the guys from Fi would probably be more than happy to give you advice on what options you should include, and box specs.
Username: Surferdude9371
Get loud or go home....
Post Number: 1538
how about instead of 2 SSD's get one 15 or 18 Q
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 1091
so you want to run 2 SSD's on a single SAE1000? is your other sundown for the highs or you already have a 1000d and just looking for a second? sry just tryin to clear things up because with only one SAE1000 you would be underpowering the subs quite a bit...
Username: Fish5
IN
Post Number: 39
Goodie- My other amp is a sundown 100.2 for my speakers, so the 1000d would be just for the subs. I've heard that 1000 watts is a good stopping point for stock electrical, and don't want to get a h/o alt. or do too much up-grading.
Whipgame-I plan on keeping the subs for a while, so probably wouldn't sell them.
I did talk to a guy at FI and he said that two SSD's would be louder than one 15 Q, so that's why i was going to go w/ the SSD's.
thanks for all of the responses!
Post Number: 1094
good call on stopping at 1000 rms for your electrical but i dont think that would be enough power for 2 SSD's rated at 800rms a piece(just a guess as i have no experience with FI products)
would you consider different subs that you could get the full potential out of? i would imagin that to be better overall...
Username: Fish5
IN
Post Number: 40
I'm open to whatever subs. I just settled on FI from what i've read on here, they seem like good products and a decent price. But if there's something better, than please let me know.
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 508
look in to getting 2 rd classic on that amp. it would be a better match up for the rms. just talk to kevin holden about the classics
Username: Shade
Moxee, Wa U.S.
Post Number: 812
i have a FI Q 18...dual 2
it'd be a perfect match for that amp
let me know.
Username: Mendonmafia
Post Number: 1602
buy that^^^ you dont have power for 2 ssd's
Username: Fish5
IN
Post Number: 41
pm sent. any other ideas?
Username: Loc_out
Team RE XXX
Post Number: 2672
Look into the RE SE i believe they are rate at 600RMS.
Username: Kingtutus
Post Number: 511
rd classics
Username: Fish5
IN
Post Number: 42
would the classics be better than an SI BM? They have packages at low-hz for both, but the SI one comes w/ a fishercustoms box.
