Digital Inputs not working NAD T773 help?
Username: Phast1
NAD AV RECEIVER T773
PROBLEM:
None of the 'DIGITAL IN' inputs work.
Inputs seem to be detected when connected but no sound.
Sound works with analog inputs & when doing 'sound test' via the remote.
Tried factory reset (video + tone defeat buttons 5sec.)
new wires - optical & digital coaxial - nothing works... any clues?
Any help or suggestions appreciated.
Username: Phast1
more info to add....
It has worked fine for 3 years (minimal use).
'Digital In' worked fine from multiple sources (HD sat box, dvd, xbox360) before it stopped altogether.
Username: Rfkelly
Bartlett, TN USA
Having the same problem out of my T763. It's been sent back to NAD twice; first to correct the non-working video connections; the second time it was for the same problem I'm having now. The digital inputs were not working then and they are not working now.
Username: Phast1
I feel for you Robert. I brought mine to a local a/v repair shop. A pc board was defective (and out of warranty). The guy said he sees this often with these particular receivers. Anyhow, $300 later it's working fine. If I didn't love this receiver (aside from this one issue) I would've replaced it.
Good luck with your efforts.
