just got hold of some seas Lotus 165 components and im having some trouble wiring it up:
the tweeter has 2 positives and 2 negatives,
Crossovers x2
2 for woofers: input, output, bypass,
2 for tweeters input output
i have the power going into the woofer input and then the bypass goin ginto the input for the tweeter cross overs,
2 positive wires in the positive output and 2 negatives in the negative output,
now it all worked for a split second, woofer is working fine, just the tweeter, i think i need a better connection any ideas? i was holding the wires by hand, and obv been very small was tricky. i touched al of the wires to there connectors on the tweeter and nothing was happening as i said it only worked for a split second,
if anyone has any info on wiring these up am i doing it correctly?
