New member Username: MeeraPICKERING, ONTARIO Post Number: 1 Registered: Nov-08 | Hey guys i need help , i lost my sun tv (6160) and ktv (6161). and i have a viewsat ultra . i did a factory bin and rescanned no sun tv or ktv came. can some1 help. i dunno much about the settings , my brother used to do this and he's away so i need to know. if some one can guide me step by step that would really help. thnx |
Silver Member Username: PizzaPost Number: 125 Registered: Nov-06 | https://www.ecoustics.com/electronics/forum/home-video/526951.html |
New member Username: MeeraPICKERING, ONTARIO Post Number: 2 Registered: Nov-08 | Pizza , those are too advanced. im like the brown version of dumb blonde. Can you tell me what i have to do from step and how to go into the menu and stuff. thnx |
Silver Member Username: PizzaPost Number: 126 Registered: Nov-06 | go to menu-->installation--->channel scan--> select 61.5 --> tp edit (see bottom of tv and yo could see buttons for different function f1 f2 f3 cf4 select edit TP {pressing suitable color button}-->add these numbers KTV 12603, V, 20000, 5/6 Video pid---7458 Pcr id----7458 Audio pid---7459 SunTv 12603, V, 20000, 5/6 Video pid---7714 PCR id----7714 Audio pid---7715 Video pid, PCR id, Audio pid can entered by edit TP scan it when you do your manual entry you could get user channel 00 , 01 ,02,03 and so on. you should check all channels by pressing up or down button there are SUN TV and KTV |
New member Username: MeeraPICKERING, ONTARIO Post Number: 3 Registered: Nov-08 | Thanks Pizza . u r the best!! i got it back .. whoohoooooooooo! |
