2.1 Axiom Speakers, need advice on receiver
Username: Millerw
MuskokaCanada
Post Number: 22
Ok! So I just got surprised with two Axiom M22 v2 Bookshelfs and an Axiom EP125 v2 Subwoofer for my birthday and I'm looking for some advice on what kind of receiver to look into. I'm assuming it should be some kind of a stereo, but I don't care about the tuner and it'll only be used for music so maybe an int amp of some kind? It's gonna be used in a bedroom (16 x 16) but I want it to shake the whole house. I'm looking to spend $500sh CDN, thanks a lot!
Bookshelfs - http://www.axiomaudio.com/m22.html
Specs: M22
Enclosure: Vortex / Reflex
Max Amp Power: 200 Watts
Min Amp Power: 10 Watts
Freq Resp +/-3dB (Hz): 60 - 22kHz Graph
Freq Resp +3dB- 9dB (Hz): 50 - 22kHz
Impedance (Ohms): 8 Ohms
SPL in Room1w/1m(dB): 93 dB
SPL Anechoic 1w/1m(dB): 89 dB
X-Over: 3.5 kHz
Tweeter: Single 1"
Woofer: Dual 5.25"
Dimens. H W D (inches): 19.8" x 7.3" x 8"
Dimens. H W D (mm): 503 x 185 x 203
Weight (lbs) each: 16 lbs
Weight (kg) each: 7.257 kg
Sub - http://www.axiomaudio.com/ep125.html
Specs: EP125
Max Amp Power: 125 Watts
Cross-over Adjust: 60 - 120 Hz
Phase: 0 & 180
Woofer Size: 8"
DSP Controlled: No
Line In and Out: Yes
Balanced Line In and Out: Yes
High Level In: Yes
Room Trim: No
Dynamic Power Supply: No
Anechoic Resp. +/- 3dB: 35 - 150 Hz
Room Resp. + 3dB/- 9dB: 25 - 150 Hz
Max SPL Anechoic: 104 dB
Max SPL In Room: 114 dB
Dimensions HWD mm: 368 x 305 x 305
Dimensions HWD inches: 14.5 x 12 x 12
Weight kg each: 9 kgs
Weight lbs each: 20 lbs
Username: Nuck
Post Number: 11158
http://nadelectronics.com/products/hifi-amplifiers/C315BEE-Stereo-Integrated-Amp lifier
Username: Artk
Albany, Oregon USA
Post Number: 8212
For just a few dollars more you can get a vastly better amp in the NAD C325BEE which is about to be discontinued and can be had online for $299 (regular $449) and worth every penny.
Username: Millerw
MuskokaCanada
Post Number: 23
Nice! Thanks! I like the look of the 325 a little better, I'm just wondering if someone could give me a nice step-by-step on how I would hook my sub up to it? I don't see a sub out and I wanna make sure I don't have to buy anything else on top of this for my sub.
http://nadelectronics.com/products/hifi-amplifiers/C325BEE-Stereo-Integrated-Amp lifier/images
Also, HK makes a similarily priced stereo receiver that has digital inputs. I'll be using the setup with my computer, which has optical digital output. I'm wondering whether or not it's going to make any real difference in quality.
http://www.harmankardon.com/product_detail.aspx?Region=USA&Country=US&Language=E NG&cat=REC&prod=HK%203490&sType=C
Thanks a bunch!
Username: Artk
Albany, Oregon USA
Post Number: 8214
Pre outs to hook up the sub...
At work no time for step-by-step...manuals are great for that.
